Old 07-21-2009, 03:26 AM
unabhan unabhan is offline
Installing Cal3D or OSG exporter
Is it possible to get the .dle, .dlo ,.dll or .mze - well whatever there is - files both for the Cal3D and the OSG-exporter without the installer stuff?
I know where to place them and what to do .
I need to export a scene from an animation which is only possible with later versions of both exporters.
My problem is I'm running 3dsmax 9 on a German computer hence the path of the program is - C:\Programme\Autodesk\3ds Max 9\- so the installer won't work as it doesn't find an installed 3dsmax version....
Any other idea to solve the problem is welcome (OK - I could install DevCC and the SDK for 3dsmax 9 and OSG and cal3d and ....but that would lead to : )
Old 07-21-2009, 10:43 AM
Can you try downloading the latest OSG exporter from our site? I've made some changes so that it should detect all localized versions of 3dsMax. I have not updated the Cal3D installer yet.
Old 07-22-2009, 09:17 AM
Thumbs up
Thanks that did the job with OSG. The exports work and nothing crashes.
Cal3d exporter problem with maya 8.5 therock Plug-in development 1 05-27-2009 05:16 PM
cal3d exporter lqakane Vizard 0 03-02-2009 08:38 AM
Maya 8.5 Cal3D exporter not working Prune Plug-in development 5 10-09-2008 06:15 PM
cal3d exporter for 3ds max 2008? masaki Plug-in development 3 09-25-2008 11:48 AM
Trouble Loading Maya7 Cal3d Exporter tbeckert Vizard 3 11-06-2007 10:38 AM
