Old 06-19-2009, 07:08 AM
manuel manuel is offline
sitting 2 animation
Hello
I've copied all animations files from the complete characters in the avatar folder. However not all animations appear in the resource windows (for instance sitting2). How can I use this animation for an avatars? Is there a list with each avatar's animations?
Old 06-22-2009, 01:08 PM
The reason that animation does not show up in the Vizard resources window is that it's not listed in the Complete Characters .cfg files. It look's like it was not intended to be released with the Complete Characters as it does not show up in the description of animations. You can try it out however by adding it to the list of animations in the cfg file for a character you're using.
Old 06-23-2009, 03:05 AM
YES ! it works. thanks. You have to add the animation in the cfg file. cool
speed on animation path whj Vizard 8 11-17-2008 07:41 PM
Jumpy animation Elizabeth S Vizard 1 11-08-2006 02:11 PM
animation sequence pkhoosh Vizard 2 01-23-2006 08:03 AM
