Old 06-04-2009, 07:16 AM
durf durf is offline
removing and obj with a timer
Is there a way to delete an object after it runs through a vizact.sequence()? Keeping in mind that there is a timer. This chunk of code below creates an object constantly and then does some actions then goes to a position that is not visible by the screen. after it reaches that position I want the object to be removed. I believe that this will speed up my program and decrease some lag. The problem is I dont know how to remove it properly after it does the runAction. Any ideas?
def scene12():
	ballLink1.enable()
	ballLink2.enable()
	ballLink3.disable()
	ballLink4.disable()
	viz.MainView.setPosition([0,8,-35]) #sets camera position
	viz.MainView.setEuler([0,-1,0]) #sets camera pitch
	rand_colors = [0,1,2,3,4]
	random.shuffle(rand_colors)
	rand_numbers = [0,1,2,3,4,5]
	random.shuffle(rand_numbers)
	rand_num = [0,1,2,3]
	random.shuffle(rand_num)
	x,y,z = ball1.getPosition()
	object = (colors[rand_colors[0]].copy())
	object.scale(.5,.5,.5)
	a,b,c = int1.getEuler()
	object.setEuler(a,0,0)
	object.setPosition([x,y-10,z])
	object.alpha(0)
	goTo1 = vizact.sequence(vizact.goto(x,y+8,z,1500),vizact.fadeTo(op[rand_num[0]],time=.7),vizact.waittime(5),vizact.goto(x,50,z,time=7))
	object.runAction(goTo1)
timer12 = vizact.ontimer2(0,viz.FOREVER,scene12)
timer12.setEnabled(viz.OFF)
