Old 05-25-2009, 03:58 AM
nasr nasr is offline
video help
hi...im trying to add a video to my application with the following code:
[code]
myroom=viz.add('room.wrl')
#Create a texture quad to display video texture
quad = viz.add(viz.TEXQUAD)
#Create a transform to scale coordinates to size of video
xform = viz.Transform()
xform.setScale(640,480,1)
#Apply texture matrix to quad
quad.texmat(xform)
#Create a video texture of type viz.TEX_RECT
myvideo = viz.add('video.mpg',viz.TEX_RECT)
#Apply video texture to quad
quad.texture(myvideo)
[\code]
and im getting the following warning..wats the reason?
Old 05-25-2009, 04:02 AM
sorry forget to post the warning..
Warning: TextureRectangle::apply(..) failed, texture rectangle is not support by your OpenGL drivers.
Old 05-26-2009, 12:42 PM
This means you either have a low-end or very old graphics card. Make sure your graphics driver is up to date. If you still have this problem, then you can work around the issue by resizing your video dimensions to a power of two (16,32,64,128,...).
lat long mapped video Brett Lindberg Vizard 3 02-25-2009 08:41 PM
Video Texturing cheezus69 Vizard 2 04-14-2008 04:26 AM
Video Texture Not Working on Some Objects paulgoldberg Vizard 1 04-17-2006 01:41 PM
How to synchronize play/pause of 2 video streams in stereo Gilliard Vizard 1 09-01-2005 09:58 AM
video jebber Vizard 1 09-28-2004 06:20 PM
