Old 05-24-2009, 01:26 AM
nasr nasr is offline
want to add a stop watch to my application!
i want to add a stop watch to my application so that when ever i press a key from the keyboard it should start the watch and when i press another key it should stop.. is there any inbuild function in vizard for a watch?
Old 05-26-2009, 12:54 PM
You can use the vizact.ontimer function to update the stop watch time. I created a simple wrapper class around this for starting/stopping the watch. Here is the sample script:
class StopWatch(object):
	def __init__(self):
		self.time = 0.0
		self._timer = vizact.ontimer(0,self._updateTime)
		self._timer.setEnabled(False)
	def _updateTime(self):
		self.time += viz.elapsed()
	def start(self):
		self._timer.setEnabled(True)
	def stop(self):
	def toggle(self):
		self._timer.setEnabled(viz.TOGGLE)
#Create stop watch object
watch = StopWatch()
#Spacebar toggles stop watch
vizact.onkeydown(' ',watch.toggle)
#Create text object to display watch time
text = viz.addText('',parent=viz.ORTHO,fontSize=40)
#Setup timer to update text object with watch time every frame
def DisplayTime():
	text.message('%.2f'%(watch.time))
vizact.ontimer(0,DisplayTime)
Old 05-31-2009, 07:32 AM
thanks for your reply...im getting this warning message!
farshizzo thanks for your reply...i tried with ur code..but im getting this message...
before Font::Glyph::subload(): detected OpenGL error 'invalid enumerant
what is the meaning of this message?
How to stop vizact.move Jerry Vizard 3 06-04-2009 05:25 PM
Stop moving after few seconds?? Chrissy2009 Vizard 8 05-10-2009 03:47 PM
collideNone() failing to stop collision spdegabrielle Vizard 3 05-07-2009 02:35 PM
Free Walkthrough Application Code Gladsomebeast Vizard 0 03-03-2009 05:02 PM
Calling Matlab application from Wizard luzanin Vizard 1 01-31-2007 10:48 AM
