Old 04-21-2009, 09:16 AM
whj whj is offline
constant speed on animation path
Hello, By pressing 'a', my script simply starts a car in a road. My question is how to make the car move in a constant speed. I use path.constantspeed(), but seems to me that the car will accelerate when it move along the circle. Does the way I add control point have problem?
import math
import time
myroad = viz.add('road4.wrl')
myroad.setPosition(0,0.1,0)
myroad.setScale(3.2,3.2,3.2)
mymini = viz.add('mini.osgx')
mymini.setPosition(-10,-10,0)
y_pos_car = 0.14
path = viz.addAnimationPath()
positions = [ [2,y_pos_car,50], [1,y_pos_car,35], [0,y_pos_car,25], [-1,y_pos_car,15],
				[-1,y_pos_car,8], [-25,y_pos_car,0], [-15,y_pos_car,-8], [-10,y_pos_car,-10],
				[-6,y_pos_car,-10], [-3,y_pos_car,-12], [0,y_pos_car,-18], [3,y_pos_car,-17],
				[6,y_pos_car,0], [10,y_pos_car,4], [15,y_pos_car,2], [25,y_pos_car,-8],
				[35,y_pos_car,-16], [50,y_pos_car,-10], [60,y_pos_car,20], [80,y_pos_car,40],
				[200,y_pos_car,200] ]
for x in range(0,len(positions)):
	cp = viz.add(viz.CONTROL_POINT)
	cp.setPosition(positions[x])
	path.add(cp,x+1)
path.loop(viz.OFF)
path.translatemode(viz.BEZIER)
path.setAutoRotate(viz.ON)
mymini.link(path)
def mytimer(num):
	pass
def onkeydown(key):
	if key == 'a':
		path.play()
		path.constantspeed(viz.ON,6.7)
viz.callback(viz.KEYBOARD_EVENT, onkeydown) #keyboard event callback
viz.callback(viz.TIMER_EVENT, mytimer) #timer event callback
viz.starttimer(0,1/60,viz.FOREVER) #timer
BTW, I cannot attach my models zip file here because it always said "Upload of file failed". What should I try?
Thanks a lot!
Old 04-21-2009, 11:17 AM
Constant speed will not work with the translate mode you are using. You could try using the linear mode or creating your animation in modeling software like 3ds Max.
Old 04-21-2009, 01:29 PM
whj whj is offline
Thanks anyway.
Problems with interaction of vizact.turn and animation path Enlil Vizard 3 11-24-2008 04:23 PM
speed on animation path whj Vizard 8 11-17-2008 07:41 PM
real time collision on animation path whj Vizard 10 10-06-2008 04:38 PM
Animation Path djdesmangles Vizard 2 06-11-2007 03:37 PM
Animation Path djdesmangles Vizard 0 06-06-2007 11:03 AM
