Old 03-26-2009, 10:58 AM
djones1010 djones1010 is offline
Transition Problems
I am having problems linking my files: GUI Title & GUI_Tutirial.
Here are some of the errors I recieve when I compile and run GUI Title:
File "GUI_Tutorial.py", line 18, in onButton
elif obj == Nxt:
NameError: global name 'Nxt' is not defined
Here are some of the errors I recieve when I compile and run GUI_Tutirial:
When I click on the "MainBtn" the words from GUI Title dont show up and the MainBtn is not removed without causing the program to shutdown.
Any Suggestions?
Old 03-30-2009, 12:31 PM
I think a better way of doing this is to hide one menu and make the other visible when you need to go back and forth
Problems loading WRL file DrunkenBrit Vizard 2 01-29-2009 12:58 AM
2 problems with our HMD Vbents Precision Position Tracker (PPT) 1 07-26-2006 07:55 PM
Problems with lighting in 2.0 murm Vizard 6 04-21-2004 09:59 AM
Problems with 3DMeNow Avatar Heads kim_swinth Vizard 9 11-19-2003 02:14 PM
