Old 03-25-2009, 02:55 PM
Enlil Enlil is offline
eMagin disconnecting after time has passed/after a sound has played
I am having a bit of a problem with the orientation sensor in the eMagin VR glasses. At a somewhat random interval, I lose contact with the glasses. If I use vizact.speech actions, I can make it fail a lot faster. I tried <sensor>.reset(), but that appears to set the current orientation to [0,0,0]. Is there a way using command() or some other function to disconnect and reconnect with the glasses?
Christian
Old 03-27-2009, 02:03 PM
Is the Emagin utility program installed on your computer? That has been known to cause problems.
Old 03-28-2009, 09:28 PM
tobin tobin is offline
Is the HMD display remaining on or is it turning off too?
Old 04-01-2009, 07:42 AM
The utility is still installed, but has been turned off - I will try uninstalling it completely and run more tests, and report the results.
The HMD still displays the scene, we just lose the tracking data. But we have never quite gotten the 3d working, so it is just a clone of the monitor.
Christian
Old 04-01-2009, 08:26 PM
Maybe the eMagin connection is timing out?
Might try installing eMagin's Lab Tool available here:
http://www.3dvisor.com/support.php
and turn off or mazimize the timeout settings.
This tool is pritty handy for other emagin stuff. But don't think you can't run it while connected to the eMagin tracker with Vizard.
Then again, the drift on the eMagin tracker is so bad its really only useful for relative gesture recognition.
timer question Elittdogg Vizard 5 10-10-2007 02:49 PM
