Old 03-17-2009, 12:59 PM
durf durf is offline
Multiple Programs Running
Is there a way to run multiple programs at the same time using the same sensors?
Im guessing no because when i try to run different programs at the same time it does not work and only allows me to run one program at a time. Im just asking incase there is a way that I am unaware of.
Old 03-24-2009, 12:51 PM
You can run multiple Vizard scripts simultaneously, but not through the Vizard IDE. You must run the scripts externally, by double clicking the .py files in Windows.
However, most sensors don't allow simultaneous access to the same device. So this might not work depending on the sensor you are using. To get around this you could setup a VRPN server and connect to the device using the VRPN plugin, which would allow simultaneous access.
creating multiple coordinate systems and making them visible jalvarez Vizard 1 02-27-2009 01:36 PM
How to load multiple LEDs into PPT ruddle Precision Position Tracker (PPT) 3 06-20-2007 01:21 AM
Multiple labs Plymouth Vizard 1 03-05-2007 10:43 AM
Problems running R3 and R2.5 on the same computer cade_mccall Vizard 5 09-05-2006 12:26 PM
running multiple vizard scripts from python exhale Vizard 1 05-09-2005 06:35 AM
