Old 03-09-2009, 05:57 AM
Moh200jo Moh200jo is offline
serial port with vizard
Can I use vizard directly to receive data through serial port and to let these data control my virtual world?
Old 03-09-2009, 11:23 AM
You can access the serial port within your Vizard script. What kind of device are you trying to connect to?
Old 03-10-2009, 09:43 AM
Thanks Jeff. May I ask here how can I use the commands with pyserial? If so, for example if the code of the speed is 160, how can I use this code to read the speed?
Chaps, any help.
Old 03-13-2009, 03:21 PM
Sorry, I don't have any experience using that module. You could try searching through the pySerial docs.
PPT talk button error: Failed to connect to COM4 jpq Precision Position Tracker (PPT) 3 12-08-2005 02:36 PM
Wireless InertiaCube3 with Vizard mspusch Vizard 0 03-01-2005 02:31 AM
A simple Plug_in for reading data from serial port sled Plug-in development 0 08-12-2003 09:52 AM
