Old 03-02-2009, 08:57 AM
just alex just alex is offline
iteration over non-sequence error
This is another noobie question, but whenever I activate what should be the car's driving path, i get a iteration over non-sequence error and I'm not sure how to fix it.
import math
import vizmat
import vizinfo
from lookingat import LookingAt
#adds the ppt
#PORT_PPT = 1
#ppt = viz.add('vizppt.dls')
#ppt.command(3,"",1,1,5) #scales ppt tracking on xyz axis
#collisions on
viz.collision(viz.ON)
view.rotate(0,1,0,90)
#gonna comment out the collision for now, it's registering when the avatar touches
#ground as a collision
#This function is called when a collision occurs
def mycollision(info):
	print 'Collided'
#Create a callback for a collision event
viz.callback(viz.COLLISION_EVENT, mycollision)
#PORT_INTERSENSE = 2
#isense = viz.add('intersense.dls')
#tracker = viz.add('intersense.dls')
#viz.tracker()
#tracker.reset()
def mykeyboard(key):
	#If the R key is pressed, reset the head orientation
	if key in ['r','R']:
		tracker.reset()
#Create a keyboard callback
#Add the street and drop it a little bit to be below the avatars feet.
street = viz.add('objects/bspcity.bsp')
street.translate(0,-.2,0)
males = []
females = []
walking = []
whichturn = 0
#List the timers.
WALKING = 0
DRIVING = 1
BLINDLOOK = 2
MALEMEETING = 3
FEMALEMEETING = 4
SITTINGWOMAN=5
FREEZESITTER=6
THROWINGMAN =7
HOLDVIEW = 8
TIMING = 9
#Add the heads for the males.
maleheads = ['Male/heads/M-015-2L.vzf','Male/heads/M-056L.vzf', 'Male/heads/M-063L.vzf']
femaleheads = []
bodyparts = ['male_legs.cmx','male_torso_LS.cmx','male_shoes.cmx']
maleclothes = ['Male/clothes/male1.jpg','Male/clothes/male2.jpg','Male/clothes/male3.jpg']
#Make some avatars.
for i in range(3):
	male = viz.add('male.cfg')
	male.translate(i,0,0)
	male.visible(0,'male_head.cmx')
	male.face(maleheads[i])
	clothes = viz.add(maleclothes[i])
	for j in bodyparts:
		male.texture(clothes,j)
	males.append(male)
for i in range(2):
	female = viz.add('female.cfg')
	female.translate(i,0,0)
	females.append(female)
#Set up paramters for walking guy.
males[0].translate(0,0,-5)
males[0].rotate(0,1,0,-90)
males[0].whichturn = 0
males[0].set = [[1.5,0,-5],[1.5,0,15],[5,0,15],[-5,0,-5]]
males[0].end = 4
males[0].state(1)
walking.append(males[0])
#Set up paramters for walking girl.
females[0].translate(1,0,-7)
females[0].rotate(0,1,0,-90)
females[0].whichturn = 0
females[0].set = [[1.5,0,0],[1,0,15],[2,0,15],[-5,0,-5]]
females[0].end = 4
females[0].state(1)
walking.append(females[0])
#Add car.
car = viz.add('mini.osgx')
#set car stuff
car.translate(-1.5,0,8)
car.rotate(0,1,0,180)
#set car path
path = viz.add(viz.ANIMATION_PATH)
positions = [[-1.5,0,8],[-1.5,0,0],[-1.5,0,-3]]
for x in range(0,len(positions)):
        cp = viz.add(viz.CONTROL_POINT)
        cp.setPosition(positions[x])
        path.add(cp,x+1)
path.constantspeed(viz.ON,1)
path.loop(viz.LOOP)
path.translatemode(viz.BEZIER)
path.setAutoRotate(viz.ON)
car.link(path)
#Set up for meeting.
males[1].translate(-9,0,21)
females[1].translate(2,0,7)
females[1].state(1)
malemoves = [2,2,4,4,2,4,4,4,4,4,4,2,2,12]
femalemoves = [6,5,12,12,1]
females[1].rotate(0,1,0,-55)
males[1].rotate(0,1,0,135)
males[1].state(1)
#Set up for throwing man.
males[2].translate(11,0,7)
males[2].state(1)
#Set up for timing.
timebomb = 0
def onkeydown(key):
	if key == '0':
		viz.starttimer(WALKING, .1, viz.PERPETUAL)
	if key == '2':
		females[1].addAction(6)
		males[1].goto(1.6,0,7.7)
		females[1].spinto(0,1,0,-55)
		females[1].state(12)
		viz.starttimer(MALEMEETING,.1)
		viz.starttimer(FEMALEMEETING,.1)
	if key == '7':
		viz.starttimer(DRIVING,.1)
	if key == '4':
		viz.starttimer(THROWINGMAN,.1)
	if key == 's':
		print 's'
		viz.starttimer(TIMING,1, viz.PERPETUAL)
def ontimer(num):
	global gravity, timebomb
	if num == WALKING:
		for agent in walking:
			agentposition = agent.get(viz.POSITION)
			agentgap = vizmat.Distance(agentposition, agent.set[agent.whichturn])
			if agentgap < .1:
				agent.whichturn += 1
				agent.state(1)
				if agent.whichturn == agent.end:
					agent.whichturn = 0
			walk = vizact.walkto(agent.set[agent.whichturn][0],agent.set[agent.whichturn][1],agent.set[agent.whichturn][2])
			agent.addAction(walk)
	if num == DRIVING:
		for agent in DRIVING:
			path.play()
	if num == MALEMEETING:
		if len(malemoves)>1:
			animation = malemoves.pop(0)
			duration = males[1].getduration(animation)
			males[1].execute(animation)
			viz.starttimer(MALEMEETING, duration-.15)
			males[1].state(animation)
	if num == FEMALEMEETING:
		if len(femalemoves)>1:
			animation = femalemoves.pop(0)
			duration = females[1].getduration(animation)
			females[1].execute(animation)
			viz.starttimer(FEMALEMEETING, duration-.15)
			females[1].state(animation)
	if num == THROWINGMAN:
		males[2].execute(9)
		males[2].execute(1)
		viz.starttimer(THROWINGMAN, 10)
	if num == HOLDVIEW:
		view.translate(-8.5,1.5,-2)
	if num == TIMING:
		print timebomb
		timebomb += 1
		if timebomb == 1:
			onkeydown('0')
		elif timebomb == 3:
			onkeydown('4')
		elif timebomb == 10:
			onkeydown('2')
		elif timebomb == 20:
			onkeydown('3')
		elif timebomb == 30:
			onkeydown('1')
		elif timebomb == 80:
			viz.quit()
viz.starttimer(HOLDVIEW,.001, viz.PERPETUAL)
Old 03-02-2009, 10:24 AM
Can you post the Python traceback error message? Python error messages usually tell you the exact line of code that caused the error and the reason for the error.
Old 03-04-2009, 01:41 PM
Here's the error
File "fixin' streetscene.py", line 199, in ontimer
TypeError: iteration over non-sequence
it tells me where the problem is, but I don't know how to fix it.
Old 03-04-2009, 01:58 PM
The error says you are iterating over an object which is not a list or sequence. It's occurring on the line "for agent in DRIVING:"
Looking at your code, the variable DRIVING is being assigned an integer value, which is not a list or sequence. You need to fix that line of code so it iterates over a list or sequence object.
Error when loading a lot of avatars dan12345 Vizard 7 07-28-2008 05:24 AM
Error Message Jerhy Vizard 1 02-28-2006 02:59 PM
Error Tracking Vygreif Vizard 1 10-03-2005 05:50 PM
Error when playing wav files...? vjonshih Vizard 1 05-23-2005 01:21 PM
The error window that couldn't FlyingWren Vizard 2 12-02-2003 09:23 AM
