Old 08-10-2004, 11:18 AM
UOL350 UOL350 is offline
Inertia Cube 2 initilization
We found that when vizard loads intersense IC2 by "viz.add('intersense.dls')", it always set IC2 with compass ON even we turned the compass OFF in isdemo(and save it to the memory to replace the factory settings), which is undesirable in many applications.
is there any command to communicate with IC2 to solve this problem in vizard? thanks.
Old 08-11-2004, 08:55 PM
The current intersense plugin has no way to turn OFF compass. I can add this feature and send you an updated version of the plugin. Please send me an email at lashkari@worldviz.com and I will get it to you as soon as possible.
