Old 12-01-2008, 10:22 PM
VizMenu still in focus after calling setVisible
Ive got this menu and when I click a button, the menu hides via setVisible. When I want to, I bring the menu back, but when I use the mouse and click the menu title to it is still in focus and does not pop out until i focus its nebore menu title.
To see issue:
Run script
Select Simulation->Next Excersize
Press spacebar
Try to select Simulation
# coding: UTF-8
import vizinfo
import vizmenu
TITLE_COLOR = (.85, .85, .85)
BGCOLOR = (0.3,0.3,.5)
TITLEBGCOLOR = (0.3,0.3,.5)
class ParameterView:
	def __init__(self, menu, parameter):
		self.parameter = parameter
		self.line = menu.add(viz.TEXT3D, '_'*15)
		self.line.color(TITLE_COLOR)
		self.label = menu.add(viz.TEXT3D, parameter.name)
#		self.slider = menu.add(viz.PROGRESS_BAR, parameter.name)
		self.slider = menu.add(viz.SLIDER)
		self.textBox = menu.add(viz.TEXTBOX)
		self.textBox.length(.5)
		self.parameterName = parameter.name
		self.sliderScaleFactor = parameter.maxValue - parameter.minValue
		self.updateViewParameterChanged()
		vizact.ontextbox(self.textBox, self.textboxChanged)
		vizact.onslider(self.slider, self.sliderChanged)
		vizact.onevent(Parameter.PARAMETER_CHANGED_EVENT, lambda e: (e.obj==self.parameter, None), self.updateViewParameterChanged)
	def setVisible(self, isVisible):
		self.line.visible(isVisible)
		self.label.visible(isVisible)
		self.slider.visible(isVisible)
		self.textBox.visible(isVisible)
	def updateViewParameterChanged(self):
		try:
			if self.parameter.value != float(self.textBox.get()):
				self.textBox.message(str(self.parameter.value))
		except ValueError:
		self.slider.set(self.parameter.value / self.sliderScaleFactor)
	def textboxChanged(self, e=None):
		if self.textBox.get() != '':
			try:
				value = float(self.textBox.get())
				self.parameter.setValue(value)
			except ValueError:
				try:
					self.textBox.message("%1.2f" % (float(e.oldText)))
				except:
					self.textBox.message('')
				viz.message('Enter only numbers')
	def sliderChanged(self, e):
		value = self.slider.get() * self.sliderScaleFactor
timeInfo = None
simParametersInfo = None
graphInfo = None
paramHistory = None
messageGroup = None
simMenu = None
def setup():
	global simParametersInfo, timeInfo, graphInfo, paramHistory, messageGroup, simMenu
#	ALPHA = .5
#	messageGroup = viz.addGroup(viz.SCREEN, pos=(.5, .80, 0), scale=[1]*3)
#	messageGroup.alpha(ALPHA)
#	background = viz.addTexQuad(messageGroup, scale=(11, 2, 0), pos=[0,0,0])
#	background.zoffset(2)
#	background.alpha(ALPHA)
#	messageGroup.t = viz.addText('asdfasdfsad', parent=messageGroup, color=viz.BLACK, pos=(-.39,.028,0), scale=[.5]*3)
#	messageGroup.t.alpha(ALPHA)
	vizmenu.MENU_FONT_SIZE = 25
	vizmenu.HIDDEN_HANGOFF_AMOUNT = 0
	vizmenu.VISIBLE_ANIMATE_SPEED = 10000
	timeInfo = vizmenu.add()
	timeInfo.setAutoHide(viz.OFF)
	simMenu = timeInfo.add('Simulation')
	timeInfo.startSimulationButton = simMenu.add(viz.BUTTON, 'Start')
	timeInfo.resetSimulationButton = simMenu.add(viz.BUTTON, 'Reset')
	timeInfo.resetSimulationButton.visible(viz.OFF)
	timeInfo.nextExercise = simMenu.add(viz.BUTTON, 'Next Exercise')
	sysMenu = timeInfo.add('System')
	timeInfo.graphOnWallCheckbox = sysMenu.add(viz.CHECKBOX, 'Draw graphs on wall')
	timeInfo.parameterHistoryWindowCheckbox = sysMenu.add(viz.CHECKBOX, 'Parameter History Table')
	timeInfo.toggleParmeterWindowsButton = sysMenu.add(viz.BUTTON, 'Toggle Parameter Windows')
	timeInfo.parameterHistoryWindowCheckbox.set(1)
	timeInfo.clearTrialHistoryButton = sysMenu.add(viz.BUTTON, 'Clear History')
	timeInfo.resetViewButton = sysMenu.add(viz.BUTTON, 'Reset View Position')
	timeInfo.showForcesButton = sysMenu.add(viz.CHECKBOX, 'Show Forces')
def setMenuVisible(isVisable):
	timeInfo.setVisible(isVisable)
	timeInfo.dirty()
	if isVisable == 0:
		simMenu.setVisible(isVisable)
		simMenu.dirty()
parameterList = []
def addParameter(param, menu):
	parameterList.append(ParameterView(menu, param))
def setParameterVisible(param, isVisible):
	for parameterView in parameterList:
		if parameterView.parameter == param:
			parameterView.setVisible(isVisible)
def addOption(name, menu):
	button = menu.add(viz.CHECKBOX, name)
	return button
def addLabel(stringy, menu):
	t = menu.add(viz.TEXT3D, '_'*15)
	t.color(TITLE_COLOR)
	t = menu.add(viz.TEXT3D, stringy)
#def setMessageVisible(isViz):
#	messageGroup.visible(isViz)
#def setMessage(stingy):
#	messageGroup.t.message(stingy)
if __name__ == '__main__':
#	viz.add('gallery.ive')
	viz.clearcolor(viz.SKYBLUE)
	setup()
	setMenuVisible(1)
	setMenuVisible(0)
	vizact.onbuttondown(timeInfo.nextExercise, setMenuVisible, 0)
	vizact.onkeydown(' ' , setMenuVisible, 1)
Old 12-02-2008, 07:42 PM
Thanks for the bug report, this will be fixed in the next release. If you need the fix sooner, then modify your vizmenu.py by replacing the setVisible function of the MenuBar class with the following code:
	def setVisible(self,visible,animate=True):
		"""Make the menu hidden or visible"""
		self.__hidden = not visible
		self.__root.clearActions()
		if self.__hidden:
			if animate:
				self.__root.runAction(vizact.moveTo(self.__inactivePos,speed=HIDING_ANIMATE_SPEED,p1=-0.5,p2=0.0))
				self.__root.translate(self.__inactivePos)
			#Clear tracked item and click state
			self.__clicked = False
			self.__trackitem(None)
			if animate:
				self.__root.runAction(vizact.goto(self.__activePos,VISIBLE_ANIMATE_SPEED))
				self.__root.translate(self.__activePos)
Old 12-02-2008, 08:47 PM
thanks for the speedy fix
Vizmenu slider bug? Gladsomebeast Vizard 2 10-22-2008 09:05 PM
