Old 11-17-2008, 02:00 AM
Anfo Anfo is offline
Problem generating exe file
Hi, I have a problem with generating an exe file.
I have a 3ds model of a landscape scene (put together from different smaller objects in OKINOs NuGraf program). There is no problem to run the script and view it, but when I ‘m trying to generate an exe file I’m getting the message:
There was an error in generating your exe file. Pleas contact WorldViz Support.
Any idea what’s wrong? What do I have to do to be able to produce an exe file from my script, and get it working?
Old 11-17-2008, 05:21 PM
Vizard will generate a log file in your TEMP directory called vizard_compiler.log. Can you email me this file after the publish fails to lashkari@worldviz.com ? If your script and all its resources are small enough, then including them will help me debug this more quickly.
Read file....many issues Uttama_vizard Vizard 9 07-08-2008 03:16 PM
File Management Uttama_vizard Vizard 2 07-01-2008 10:44 AM
texture problem with .wrl file whj Vizard 5 05-01-2008 03:09 PM
Problem on adding OSG file felixchc Vizard 4 10-06-2006 12:26 PM
