Old 11-15-2008, 08:59 PM
Matt Wheeler Matt Wheeler is offline
Can Vizard load TrianGraphics .ive files?
I'd like to load these example .ive files into Vizard.
http://www.triangraphics.de/index.ph...Database&l=eng
Any idea why it doesn't work?
Matt Wheeler
Old 11-16-2008, 01:58 PM
tobin tobin is offline
The .IVE files on the TrianGraphics.de website use a later version of OpenSceneGraph than the version Vizard is based on so the .iVE files will not load directly into Vizard. I see that some of the samples are available as OpenFlight. If you have 3DS Max, its newer releases include OpenFlight import functionality. You might try importing as OpenFlight into 3DS Max, and then export as the Vizard compatible OSG/IVE format (which you can download here: http://www.worldviz.com/download/fil...9.4Install.exe).
Old 12-22-2008, 01:37 PM
dtidrow dtidrow is offline
Another possibility...
is to convert the .ive files into .osg (ie. "osgconv file.ive file.osg"), using a recent version of osgconv. Generally, you can load .osg files made with more recent versions of OSG into applications made with older versions of OSG.
Old 03-21-2012, 12:41 PM
dthomas dthomas is offline
I had the aforementioned problem. Exporting the models as .osg like this fixed it in Vizard 3.
Incampatible CAL3D files luakt Vizard 4 09-15-2008 12:28 AM
Fall 2007 release of Vizard R3 3 D Announcements 0 10-15-2007 05:50 PM
How to edit .IVE files michelcm3 Plug-in development 3 07-12-2007 10:37 AM
loading large wav files in vizard tommahhh Vizard 1 05-16-2005 04:23 PM
