Old 10-11-2008, 07:15 PM
vSklesser vSklesser is offline
Noisy voice files
Hello, I'm adding voice files into vizard for avatars to talk with via the
avatar.addAction(vizact.speak('filename.wav'))
and the sound is very very noisy, it seems much noisier than when they are played in a media player. The file is a PCM 8-bit 22 kHz encoded mono wav file. Is this due to how vizard processes the sound or maybe how the file is encoded? Or do any sound files that vizard uses have to be perfectly noiseless? What should I do?
Old 10-12-2008, 02:00 AM
masaki masaki is offline
hi,
if you can re-record the sound file, i would suggest recording at a higher bit depth (16bit) and a higher sampling rate (44,100 hz) and in stereo.
How to edit the skin tones of the complete characters' cfg files? vEsotu Vizard 3 09-23-2008 01:07 PM
Which software can be used to edit .cfg (CAL3D) files luakt Vizard 4 09-12-2008 08:18 AM
Error when playing wav files...? vjonshih Vizard 1 05-23-2005 01:21 PM
loading large wav files in vizard tommahhh Vizard 1 05-16-2005 04:23 PM
Including Files that Include Other Files vjosh Vizard 1 09-21-2004 05:44 PM
