Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 10-07-2008, 04:10 PM
TrashcanPatrol TrashcanPatrol is offline
Using hotspots to enable opening doors
Hello, I have a question about hotspots. How is it possible to use a hotspot to enable someone to open a door?
What I'm looking for is for the player to walk up to a door, being right next to the door will enable him/her to actually use the command to open the door.
My code is as follows:
def onHotspot(id,x,y,z):
	if id == door:
             def mykeyboard(key):
  # If the user presses the e key do something
  if key == 'e':
    # Open the door
    door.runAction( vizact.spinto(0,1,0, -90, 30.0) )
viz.callback(viz.HOTSPOT_EVENT,onHotspot)
Now, I know that won't work as it is. How can I change it so that the player can only open the door when they're in the hotspot?
Thanks in advance
Old 10-07-2008, 04:28 PM
Also, just curious, is there a way to view the hotspots so as to make it easier to move them around?
Old 10-08-2008, 05:22 PM
you could set a variable that is true when one is inside or false when outside of the hotspot. Then if the door key is pressed and the value is true you open the door.
here is a link to some code that keeps track of whether you have entered or left a hotspot. it also draws a circle where one of the hotspots is. Look at the code at the end of the post
http://www.worldviz.com/forum/showth...hlight=hotspot
then you could add something like
def onKeyDown(key):
	if key == 'e' and inHotspot == True:
		print "open the door"
Old 10-14-2008, 03:34 PM
Hi thank you for your response, I've tried what you said but it doesn't work still. Here is what I tried:
SAFE = 1
UNSAFE = 2
TARGET = 3
CIRCLE_X = -3.5
CIRCLE_Z = 3.4
CIRCLE_RADIUS = 0.5
def handlemyhotspots(id,x,y,z):
	if id == SAFE:
		print 'inside safe zone'
			if key == 'e':
		viz.clearcolor(1,1,1)
		viz.starthotspot(UNSAFE,viz.RECTANGLE_HOTSPOT_OUT,0,3,2.4,6)
	elif id == UNSAFE:
		print 'outside safe zone'
		viz.clearcolor(0,0,0)
		viz.starthotspot(SAFE,viz.RECTANGLE_HOTSPOT_IN,0,3,2.4,6)
	elif id == TARGET:
		print 'at target'
viz.callback(viz.HOTSPOT_EVENT, handlemyhotspots)
viz.starthotspot(TARGET,viz.CIRCLE_HOTSPOT_IN,CIRCLE_X,CIRCLE_Z,CIRCLE_RADIUS)
import math
viz.startlayer(viz.LINES)
viz.linewidth(3)
viz.vertexcolor(viz.RED)
viz.vertex(CIRCLE_X,0,CIRCLE_Z)
viz.vertex(CIRCLE_X,2,CIRCLE_Z)
viz.startlayer(viz.LINE_LOOP)
for a in range(0,360,10):
	x = math.sin(viz.radians(a))*CIRCLE_RADIUS
	z = math.cos(viz.radians(a))*CIRCLE_RADIUS
	viz.vertex(x+CIRCLE_X,0.1,z+CIRCLE_Z)
viz.endlayer()
room=viz.add('room.wrl')
viz.collision(viz.ON)
door = room.getchild('door-FACES')
import vizcam
vizcam.FlyNavigate()
  if key == 'e' and id == SAFE:
--but it doesn't let me open the door like that though. The boldened part I know won't work [and it's not in my code that I was just using] but that's what I'm trying to do with it, it's hard to describe using two definitions with words though.
What do you think I should do for that?
Old 10-14-2008, 04:27 PM
There are two problems with your code. First your mykeyboard function should not be inside of you handlemyhotspots function. You also need a viz.callback line. Try the following code.
Once you enter the safe zone the variable openDoor will be set to true. When you leave the safe zone openDoor is set to false. When you press a key the onKeyDown function will be called. If openDoor is true and the keypressed is 'e' you will be able to open the door.
viz.MainView.setPosition(0,1.8,-5)
SAFE = 1
UNSAFE = 2
TARGET = 3
viz.add('tut_ground.wrl')
CIRCLE_X = 0
CIRCLE_Z = 3
CIRCLE_RADIUS = 0.5
openDoor = False
	global openDoor
	if id == SAFE:
		openDoor = True
	elif id == UNSAFE:
		openDoor = False
	elif id == TARGET:
		print 'at target'
import math
viz.linewidth(3)
viz.endlayer()
def onKeyDown(key):
	if key == 'e' and openDoor == True:
Old 10-16-2008, 03:19 PM
It worked like a charm, thanks!
...Do you know of a way that one can bind an avatar to the viewpoint, and use the door in a way where, the user presses 'e' and sees the avatar's hand opening the door? If not, that's okay, this will do perfectly.
Old 10-20-2008, 05:58 PM
You can link the viewpoint to the avatar and manipulate the arm bone so it moves to the doorknob. Here's an example using a link with an offset so the viewpoint is behind the avatar. When the avatar stops moving he raises his arm.
viz.add('court.ive')
link = viz.link(avatar, viz.MainView)
link.preTrans([0,0,-2])
walk = vizact.walkTo([0,0,5])
armup = vizact.boneSpinTo('Bip01 R UpperArm', euler = [0,0,-75], speed = 45)
avatar.addAction(walk)
avatar.addAction(armup)
Old 10-21-2008, 03:42 PM
Hmm... I'm having some difficulty combining this into an environment where there's a door to open. Here is my code so far:
SAFE = 1
UNSAFE = 0
RECTANGLE_X = -4
RECTANGLE_Z = 3.4
RECTANGLE_WIDTH = 0.5
openDoor = False
dooropen = False
walk = vizact.walkTo([-3.5,0,3.5])
	global openDoor
	if id == SAFE:
		openDoor = True
		print 'Door can be opened'
		viz.starthotspot(UNSAFE,viz.RECTANGLE_HOTSPOT_OUT,RECTANGLE_X,RECTANGLE_Z,RECTANGLE_WIDTH,1)
	if id == UNSAFE:
		openDoor = False
		print 'Door can not be opened'
		viz.starthotspot(SAFE,viz.RECTANGLE_HOTSPOT_IN,RECTANGLE_X,RECTANGLE_Z,RECTANGLE_WIDTH,1)
#viz.starthotspot(TARGET,viz.CIRCLE_HOTSPOT_IN,CIRCLE_X,CIRCLE_Z,CIRCLE_RADIUS)
import vizcam
link.preTrans([0,0,.1])
	global dooropen
		dooropen = True
		avatar.action(armup)
#Further help: http://www.worldviz.com/vizhelp/commands/viz/starthotspot.htm
#	if dooropen == True:
#		print 'The door is open'
#	if key == 'e' and openDoor == True and dooropen == True:
#		door.runAction(vizact.spinto(0,1,0,0,30.0) )
#Need to be able to close door as well, for concept.
#after door is opened, dooropen = True
#if key == 'e' and dooropen == True:
	#door.runAction( vizact.spinto(0,1,0,0,30.0) )
avatar.disable(viz.INTERSECTION)
I'm having some trouble controlling the viewpoint. It's linked to the avatar I know, but is there any way to control the avatar to go forward/back with Up, Down and strafe with Left, Right? As well as use the mouse to look around, so the player sees the hand open the door.. is this possible?
Thanks again for sticking around and helping me a bit through this.
