Old 10-07-2008, 06:09 AM
digitaldarklord digitaldarklord is offline
Send a message via MSN to digitaldarklord Send a message via Skype™ to digitaldarklord
custom DLL = viz.add('yourstuff.dle')
Greetings
In the old days when using macromedia director you could simply call the available functions in a external extra ?
My question is this : is it possible to call the available functions in a DLE and can you return the default syntax of such a function (if this is implemented)?
Old 10-07-2008, 04:28 PM
I'm not 100% sure what you are asking. To be clear, you want to execute functions in arbitrary DLL files? If so, you can use the ctypes library that comes with Vizard. Here is a tutorial on how to use it, http://python.net/crew/theller/ctypes/tutorial.html
Let me know if I misunderstood your question.
Custom Drop-Down Menus and Sliders south_bank Vizard 2 05-20-2008 04:27 AM
Custom Render .EXE export vaestebob Plug-in development 2 05-12-2008 07:55 AM
problems adding a custom morph head to a custom body Greenwu Vizard 1 07-27-2006 10:32 AM
animating custom faces: in search of "open_mouth" morphs vr_boyko Vizard 1 09-16-2004 10:30 AM
Creating Custom Avatar Heads farshizzo Vizard 22 09-12-2004 09:23 PM
