Old 08-22-2008, 12:10 PM
Vista, Cal3d, Max 2008
Sorry to bother you with more Cal3D woes, but I'm having a problem
with it recognizing the plugin.
I'm using Vista 64-bit with a 32-bit version of max.
When I install the Cal3D .exe from WorldViz for max 2008, everything
goes fine.
When I open max it tells me:
DLL <C:\Program Files (x86)\Autodesk\3ds Max 2008\PlugIns\cal3d_max_exporter.dle> failes to initialize.
Error code: 126 - The specified module could not be found.
The OSG install from worldviz works perfectly.
But for some reason I can't seem to get the CAL3D to work.
I looked in the plugins folder and there is a cal3d_max_exporter.dle
I also looked in the main directory and there is a cal3d.dll
Any suggestions?
George L.
Rowan University
Old 08-25-2008, 05:32 PM
Did you run the installer as an administrator?
Old 08-27-2008, 02:45 AM
Hi, shivanangel,
I use 32 bit max 2008 on vista ultimate 64 bit for all the graphics work I do here at worldviz. I have the same plugins in the same folders as you.
Since it works fine here I'm not sure how to troubleshoot this one. Farshid (farshizzo) may have more insight.
Michael Nicolayeff
3d Graphics Artist
Worldviz LLC
Old 09-01-2008, 10:27 AM
I am still unable to get the plug-in to work on my 64-bit
machine with Vista and a 32-bit version of max.
However, it appears to work on my XP 32-bit.
George Lecakes
Rowan University
Old 09-25-2008, 10:29 AM
nanook_at nanook_at is offline
Cal3d, Max 2008
Hello !
Where can i download Cal3d - Max 2008 plugin ???
the only version i could find is for MAX 7
Thanks !
Old 09-25-2008, 10:48 AM
All of our exporters are available on our download page.
Old 09-25-2008, 02:26 PM
Thumbs up Cal3d, Max 2008
Thanks ! Got it !
cal3d exporter for 3ds max 2008? masaki Plug-in development 3 09-25-2008 10:48 AM
Installation fails for 3ds max 2008 atuin Vizard 5 09-13-2008 10:22 AM
Windows Vista Steve_HT Vizard 1 05-10-2007 10:30 AM
importing avatars with cal3d marcoleon Vizard 15 04-28-2006 04:48 PM
importing cal3d in 3ds? shai Vizard 1 11-01-2004 10:19 AM
