Old 07-17-2008, 01:18 PM
fc2008 fc2008 is offline
what does this error code mean?
Heya im getting this error, im trying to make it so when the left mouse button is pressed an event occurs,
but i Keep getting the following error:
if info.valid and info.object == female:
UnboundLocalError: local variable 'info' referenced before assignment
any thoughts? the code is below:
import vizinfo
female = viz.add('vcc_female.cfg')
viz.translate(viz.HEAD_POS,0,20,-30)
viz.lookat(0,0,0)
viz.mouse(viz.OFF)
viz.clearcolor(0.5,0.5,1)
#Add the vizinfo object with a message.
infoObject = vizinfo.add('Give me feedback!')
infoObject.visible(0)
#Give it a title.
infoObject.title('Vizinfo box')
#Add GUI elements with labels.
button = infoObject.add(viz.BUTTON, 'Push me')
slider = infoObject.add(viz.SLIDER, 'Slide me')
check = infoObject.add(viz.CHECKBOX, 'Check me')
#Adjust the parameters of one of the GUI elements.
slider.vertical()
def mouse(button):
			info = viz.pick(1)
			if info.valid and info.object == ground:
				walk = vizact.walkTo([info.point[0],0,info.point[2]])
				avatar.runAction(walk)
				infoObject.visible(1)
viz.callback(viz.MOUSEDOWN_EVENT,mouse)
thankyou for your time
Old 07-17-2008, 04:17 PM
You are creating the info variable in a different indentation block than the if statement. So if the right mouse button was clicked you would get an error because the info object would never be created. So you need to indent the if info.valid and info.object == female: block so it is in the same scope as the line info = viz.pick(1)
Old 07-17-2008, 05:38 PM
Thumbs up thanks
cheers, thats sorted a lot of the problems ive been havin
Also I was wondering if there could be a scripts page in the future on here, so users can share scripts etc?
Thankyou for your time
