Old 07-16-2008, 07:36 AM
fc2008 fc2008 is offline
Thumbs up heya everybody, just a quick one
Heya, im new to the forum- ive encountered this error message, my code is as follows,
if obj == ollie_slider:
NameError: name 'obj' is not defined
iv highlighted where the object is being called below.
i know i must be missing an object somewhere cant find it though
Thankyou for your help
###COPYRIGHT 2008 FC###
import vizinfo
#remove movement of screen wi mouse
viz.mouse(viz.OFF)
info = vizinfo.add( '' )
info.translate( .98, .1 )
info.titlebgcolor(1,0,0)
viz.clearcolor(0.5,0.5,1)
#Add object that vizinfo GUI objects will modify
#=============male or female
male = viz.add('vcc_male.cfg')
female = viz.add('vcc_female.cfg')
#==========morphing face========#
male_morphing_face= male.face('morph_head.vzf')
female_morphing_face = female.face('morph_head.vzf')
#============morphing face end============#
male = info.add(viz.RADIO,0,'Male')
female = info.add(viz.RADIO,0,'Female')
vizact.onbuttondown( male, male.color,viz.BLUE)#Keyboard commands that modify the info box
vizact.onbuttondown( female,female.color,viz.WHITE) #Keyboard commands that modify the info box
#===========male or female end
male.setPosition(0,1,3)
female.setAxisAngle(0,1,0, 180)
#===============set angles directions of models
#============Initialize info box with some instructions#=================
info = vizinfo.add( 'Set the appearence of your employee' )
info.title( 'Employee Spin' ) #Set title text
info.drag( viz.ON ) #Make the title bar draggable
#Add slider in info box
slider = info.add( viz.SLIDER, 'Spin Speed' )
slider.setScale( 2, 2, 2 )
slider.label.color( viz.RED )
#colours===================
#Add radio buttons
red = info.add( viz.RADIO, 0, 'Red' )
white = info.add( viz.RADIO, 0, 'White' )
blue = info.add( viz.RADIO, 0, 'Blue' )
#Set callbacks for changing  color with radio buttons
vizact.onbuttondown( red, male.color, viz.RED )
vizact.onbuttondown( white, male.color, viz.WHITE )
vizact.onbuttondown( blue, male.color, viz.BLUE )
vizact.onbuttondown( red, female.color, viz.RED )
vizact.onbuttondown( white, female.color, viz.WHITE )
vizact.onbuttondown( blue, female.color, viz.BLUE )
#colors end===================
#====================INFO WINDOW OPTIONS#============
def keyboardEvent( key ):
	if key == 'e':
		info.expand() #Maximize info box
	elif key == 's':
		info.shrink() #Minimize info box
	elif key == 'm':
		info.message( viz.input('Your employee\n\'s name:') ) #Change directions message
	elif key == 't':
		info.title( viz.input('Enter title text:') ) #Change title message
viz.callback( viz.KEYBOARD_EVENT, keyboardEvent )
#======================INFO WINDOW OPTIONS
def sliderEvent( pos ):
	#Make wheelbarrow spin according to slider position
	male.runAction( vizact.spin(0, -1, 0, 500 * pos) )
	female.runAction( vizact.spin(0, -1, 0, 500 * pos) )
	vizact.onslider( slider, sliderEvent )
#=====================actions of characters - MALE========================#
def mykeyboard(key):
    if key == '1':
        male.state(1)
    elif key == '2':
        male.state(2)
    elif key == '3':
        male.state(3)
    elif key == '4':
        male.state(4)
    elif key == '5':
        male.state(5)
    elif key == '6':
        male.state(6)
    elif key == '7':
        male.state(7)
    elif key == '8':
        male.state(8)
    elif key == '9':
        male.state(9)
    elif key == '0':
        male.state(10)
    elif key == 'a':
        male.state(11)
    elif key == 'b':
        male.state(12)
    elif key == 'c':
        male.state(13)
    elif key == 'd':
        male.state(14)
    elif key == 'e':
        male.state(15)
#=====================actions of characters - FEMALE========================#
    if key == '1':
        female.state(1)
    elif key == '2':
        female.state(2)
    elif key == '3':
        female.state(3)
    elif key == '4':
        female.state(4)
    elif key == '5':
        female.state(5)
    elif key == '6':
        female.state(6)
    elif key == '7':
        female.state(7)
    elif key == '8':
        female.state(8)
    elif key == '9':
        female.state(9)
    elif key == '0':
        female.state(10)
    elif key == 'a':
        female.state(11)
    elif key == 'b':
        female.state(12)
    elif key == 'c':
        female.state(13)
    elif key == 'd':
        female.state(14)
    elif key == 'e':
        female.state(15)
#------------------adding a slider to change the heads
#add slider for smile
smile_slider = viz.add(viz.SLIDER)
smile_slider.translate(0.25,0.1)
#slider 2 for face more to the world
ollie_slider = viz.add(viz.SLIDER)
ollie_slider.translate(0.75,.1)
#------------------end slider
#---------morph head
#add two differnt face images
first_texture = viz.add('stan.jpg')
second_texture = viz.add('ollie.jpg')
#paste both faces to the head
male_morphing_face.texture(first_texture)
male_morphing_face.texture(second_texture, '',1)
female_morphing_face.texture(first_texture)
female_morphing_face.texture(second_texture, '',1)
#frag program to blend textures
blend = viz.add('multiexblend.fp')
male_morphing_face.apply(blend)
blend.param(0,0) #bledning it
female_morphing_face.apply(blend)
#--------------end morph head
#--------slider function
#Define the slider function to handle the information #from the sliders. def myslider(obj,pos): if obj == smile_slider: #Morph the face to its first (0) morph target. male_morphing_face.morph(0,pos) female_morphing_face.morph(0,pos) if obj == ollie_slider: #Blend the fact texture to the second texture. blend.param(0,pos)
#Morph the face to its second (1) morph target. male_morphing_face.morph(1,pos) female_morphing_face.morph(1,pos) viz.callback(viz.SLIDER_EVENT,myslider) ##INFOBOX smile_box = vizinfo.add( 'This tutorial demonstrates the use of the vizinfo module.' ) smile_box.translate( .40, .1 ) #Initialize info box with some instructions smile_box = vizinfo.add( 'Check out the smile' ) smile_box.title( 'Smile' ) #Set title text smile_box.drag( viz.ON ) #Make the title bar draggable
Old 07-16-2008, 04:31 PM
The quotes you put around the highlightes section of code caused it to lose all formatting. You need to repost that section without putting it inside the quotes tag.
Old 07-16-2008, 05:29 PM
Cool, iv added it below, regards
import vizinfo
viz.mouse(viz.OFF)
#Add radio buttons
	if key == 'e':
	elif key == 's':
	elif key == 'm':
	elif key == 't':
    if key == '1':
        male.state(1)
    elif key == '2':
        male.state(2)
    elif key == '3':
        male.state(3)
    elif key == '4':
        male.state(4)
    elif key == '5':
        male.state(5)
    elif key == '6':
        male.state(6)
    elif key == '7':
        male.state(7)
    elif key == '8':
        male.state(8)
    elif key == '9':
        male.state(9)
    elif key == '0':
        male.state(10)
    elif key == 'a':
        male.state(11)
    elif key == 'b':
        male.state(12)
    elif key == 'c':
        male.state(13)
    elif key == 'd':
        male.state(14)
    elif key == 'e':
        male.state(15)
    if key == '1':
        female.state(1)
    elif key == '2':
        female.state(2)
    elif key == '3':
        female.state(3)
    elif key == '4':
        female.state(4)
    elif key == '5':
        female.state(5)
    elif key == '6':
        female.state(6)
    elif key == '7':
        female.state(7)
    elif key == '8':
        female.state(8)
    elif key == '9':
        female.state(9)
    elif key == '0':
        female.state(10)
    elif key == 'a':
        female.state(11)
    elif key == 'b':
        female.state(12)
    elif key == 'c':
        female.state(13)
    elif key == 'd':
        female.state(14)
    elif key == 'e':
        female.state(15)
#from the sliders.
    blend.param(0,pos)
##INFOBOX
Old 07-16-2008, 06:33 PM
Thanks, that's much better now. The problem is that the if block starting on the line if obj == ollie_slider: is not indented properly. You need to indent that block of code so that it is part of the myslider function. Otherwise, that code is part of the global scope, which does not contain an obj variable, hence the error.
Old 07-17-2008, 05:52 AM
Thumbs up thankyou
thanks a lot, its always the simple ones that catch me out!
quick display question timbo Vizard 1 07-09-2008 04:53 PM
Quick Question nige777 Vizard 5 05-08-2008 06:50 AM
