Old 06-16-2008, 10:48 PM
guxmy01 guxmy01 is offline
how to create ground?
rather than using the provided script for ground (viz.add('tut_ground.wrl')), how can i insert my own ground?is it in jpeg format or wrl?
Old 06-17-2008, 11:38 AM
If you want to apply your own texture to the existing ground model then you can use the following code:
tex = viz.add('mytexture.jpg')
ground.texture(tex)
Or you can create your own ground model using a 3D editor and import it directly into Vizard.
questions on how to create a form xingxing Vizard 15 06-13-2008 05:19 PM
How to create a sky? guxmy01 Vizard 1 05-28-2008 01:07 PM
Create my own animations michelcm3 Vizard 1 09-21-2007 10:53 AM
how to create morph from the comple characters CD michelcm3 Vizard 9 07-19-2007 11:15 AM
