Old 06-12-2008, 07:54 PM
Exclamation BumpMapping
Hello Wizard,
My BumpMapping shader is almost working !!! Except that my texture is going bye bye on some faces of my model... Can you tell me what is wrong ? I don't understand how to use the "attributes" in Vizard neither.
I've attached the test. It's a rar file that I've renamed to zip for the uploading.
Ciao !!
D.
Old 06-13-2008, 01:16 PM
To the fix the texture issue, you need to enable texture repeating. Use the following code when adding the textures:
baseMap = viz.addTexture('Fieldstone.dds',wrap=viz.REPEAT)
bumpMap	= viz.addTexture('Fieldstone_nm.png',wrap=viz.REPEAT)
Regarding the shader attributes, Vizard suppports computing tangent data for your mesh. I've modified your VirtualFX.py file to use this feature. I just modified a small portion of the vertex shader and enabled tangent computation on the shader object:
class BumpMapping(object):
	def __init__(self):
		self.__vert = """
		uniform vec3 fvLightPosition;
		uniform vec3 fvEyePosition;
		varying vec2 Texcoord;
		varying vec3 ViewDirection;
		varying vec3 LightDirection;
		attribute vec3 Tangent;
		void main( void )
			gl_Position = ftransform();
			Texcoord    = gl_MultiTexCoord0.xy;
			vec4 fvObjectPosition = gl_ModelViewMatrix * gl_Vertex;
			vec3 fvViewDirection  = fvEyePosition - fvObjectPosition.xyz;
			vec3 fvLightDirection = fvLightPosition - fvObjectPosition.xyz;
			vec3 fvNormal         = gl_NormalMatrix * gl_Normal;
			vec3 fvTangent        = gl_NormalMatrix * Tangent;
			vec3 fvBinormal       = cross(fvNormal, fvTangent);
			ViewDirection.x  = dot( fvTangent, fvViewDirection );
			ViewDirection.y  = dot( fvBinormal, fvViewDirection );
			ViewDirection.z  = dot( fvNormal, fvViewDirection );
			LightDirection.x  = dot( fvTangent, fvLightDirection.xyz );
			LightDirection.y  = dot( fvBinormal, fvLightDirection.xyz );
			LightDirection.z  = dot( fvNormal, fvLightDirection.xyz );
		self.__frag = """
		uniform vec4 fvAmbient;
		uniform vec4 fvSpecular;
		uniform vec4 fvDiffuse;
		uniform float fSpecularPower;
		uniform sampler2D baseMap;
		uniform sampler2D bumpMap;
		void main( void )
			vec3  fvLightDirection = normalize( LightDirection );
			vec3  fvNormal         = normalize( ( texture2D( bumpMap, Texcoord ).xyz * 2.0 ) - 1.0 );
			float fNDotL           = dot( fvNormal, fvLightDirection );
			vec3  fvReflection     = normalize( ( ( 2.0 * fvNormal ) * fNDotL ) - fvLightDirection );
			vec3  fvViewDirection  = normalize( ViewDirection );
			float fRDotV           = max( 0.0, dot( fvReflection, fvViewDirection ) );
			vec4  fvBaseColor      = texture2D( baseMap, Texcoord );
			vec4  fvTotalAmbient   = fvAmbient * fvBaseColor;
			vec4  fvTotalDiffuse   = fvDiffuse * fNDotL * fvBaseColor;
			vec4  fvTotalSpecular  = fvSpecular * ( pow( fRDotV, fSpecularPower ) );
			gl_FragColor = ( fvTotalAmbient + fvTotalDiffuse + fvTotalSpecular );
		# Creating shader
		self.__shader = viz.addShader(vert=self.__vert, frag=self.__frag,flag=viz.SHADER_TANGENT)
		# Adding vertex uniforms
		ufvLightPosition	= viz.addUniformFloat('fvLightPosition', 0, 0, 0);
		ufvEyePosition 		= viz.addUniformFloat('fvEyePosition', 0,0,0);
		#urm_Binormal 		= viz.addUniformFloat('rm_Binormal', 0,0,0);
		#urm_Tangent 		= viz.addUniformFloat('rm_Tangent', 0,0,0);
		# Adding fragment uniforms
		ufvAmbient		= viz.addUniformFloat('fvAmbient', .35,.35,.35,1);
		ufvSpecular 	= viz.addUniformFloat('fvSpecular',.50,.50,.50,1);
		ufvDiffuse 		= viz.addUniformFloat('fvDiffuse', .80,.80,.80,1);
		ufSpecularPower	= viz.addUniformFloat('fSpecularPower', 5);
		ubaseMap 		= viz.addUniformInt('baseMap', 0);
		ubumpMap		= viz.addUniformInt('bumpMap', 1);
		self.__shader.attach(ufvLightPosition)
		self.__shader.attach(ufvEyePosition)
		#self.__shader.attach(urm_Binormal)
		#self.__shader.attach(urm_Tangent)
		self.__shader.attach(ufvAmbient)
		self.__shader.attach(ufvSpecular)
		self.__shader.attach(ufvDiffuse)
		self.__shader.attach(ufSpecularPower)
		self.__shader.attach(ubaseMap)
		self.__shader.attach(ubumpMap)
	def applyfx(self, node):
		node.apply(self.__shader)
Old 06-14-2008, 06:16 AM
Thumbs up Thanks !!
Thanks Farshi,
It's working...
viz.FOREVER !!
D.
