Old 06-09-2008, 10:04 AM
Enlil Enlil is offline
'ActionData' object is not callable error
I am attempting to make a class that manages the actions of a 3d avatar. I am new at python and vizard, so I may be missing something fundamental. Never the less, here is my problem:
I define my class like so if a file called test1.py:
class testclass:
def __init__(self):
self.female = viz.add('vcc_female.cfg')
self.face = viz.add('biohead_talk.vzf')
self.female.setFace(self.face)
self.female.state(14)
self.female.translate(0.3,0.1,1)
self.female.rotate(0,1,0,180)
self.smile = smile = vizact.morph('smile', .5, .1)
def smile():
self.face.add(self.smile)
Then, in a second file, speech_test.py, I write the following:
import test1
foo2 = testclass()
foo2.smile()
I then get the error
File "speech_test2.py", line 18, in ?
foo2.smile()
TypeError: 'ActionData' object is not callable
Can anyone tell me why this is happening and what I need to do to fix it?
Christian
Old 06-09-2008, 11:23 AM
Thumbs up
Oops, the above was unreadable - let me try again (and make a couple of corrections):
test1.py:
mport viz
class testclass:
def __init__(self):
self.smile = vizact.morph('smile', .5, .1)
def smile(self):
The rest should be ok (I was not passing self to smile, but upon adding self to the def, I still got the same error).
Christian
edit: it flattened everything again, so I used the indent feature this time . . .
Old 06-09-2008, 06:03 PM
Please use the [code][/code] tags when posting code samples. It will preserve indentations.
The problem with your code is that you assign the smile action to a variable called smile which will overwrite the smile method. You need to give it a name that does not conflict with the smile method.
'int' object not callable enkeli Vizard 8 10-22-2009 05:12 PM
Unscriptable Object Error shivanangel Vizard 1 10-11-2006 12:04 PM
Error Message Jerhy Vizard 1 02-28-2006 02:59 PM
