Old 04-22-2004, 07:02 AM
Plasma Plasma is offline
Field of View
When not in HMD mode, how large is the viewer's field of view (in degrees). What about when in HMD mode?
Old 04-22-2004, 10:14 AM
The default vertical FOV is 40 degrees with a 1.3 aspect ratio. This is the same in HMD and non HMD mode. You can change this value to whatever you wish. Example:
#change to 60 degree vertical FOV with aspect ratio of 1
viz.fov(60,1)
