Old 03-13-2008, 10:01 AM
Jerry Jerry is offline
audio object string
The following script contains a function which attempts to play
an audio file which is passed as
an argument. Before calling the function I want to construct the
name of the audio object by concatenating character strings, but
it doesn't work. Can you tell me the correct way to do this?
from viz import *
go()
sound1 = add('boing!.wav')
def playit(snd):
	snd.play()
num = 1
s = 'sound'+str(num)
playit(s)
Old 03-13-2008, 11:06 AM
Are you trying to look up a Python object by its name? The following will look up the name in the current global variable scope and play the sound if it exists:
def playit(snd):
	soundObject = globals().get(snd,None)
	if soundObject is not None:
		soundObject.play()
Child Object Rotation paulgoldberg Vizard 5 09-05-2006 11:33 AM
when collision mode is on, can i "turn it off" for an individual object? Vdoug Vizard 1 09-22-2005 12:14 PM
Getting the String of a Text3d Object vjosh Vizard 1 01-03-2005 11:37 PM
