Old 02-27-2008, 12:25 PM
erchrastil erchrastil is offline
vizact.fall
i'm trying to make an environment using a tracker that gives a visual appearance of falling, but the actual tracker doesn't move. i have something that works fine when i'm just using keyboard commands to move, but it doesn't seem to work with the tracker.
here is the code i'm using:
fallAction = vizact.fall(-28.18)
if view.getPosition(mode=viz.ABS_GLOBAL)[0] > 1.0
view.add(fallAction)
this is enclosed within a timer loop that generally controls all of the actions:
def masterLoop(num):
viz.callback(viz.TIMER_EVENT,masterLoop)
viz.starttimer(0,1/60.0,viz.FOREVER)
but here is the error message i get, which seems to want some sort of timer:
AttributeError: 'VizFallAction' object has no attribute 'elapsed'
File "C:\Program Files\WorldViz\Vizard30\python\viz.py", line 8030, in __update
curAction.update(elaps,curAction._obj_)
File "C:\Program Files\WorldViz\Vizard30\python\vizact.py", line 479, in update
self.elapsed += elapsed
any suggestions?
Old 02-27-2008, 04:04 PM
You should be getting another error message before the one you posted. What does that one say? What kind of object is the view object? The easiest way for me to solve the problem would be if you posted an entire script that reproduces the error.
Old 02-27-2008, 07:12 PM
for this code, view is just the vizard mainview:
view = viz.MainView
here is a stripped down version of the code. there are a few models at the top which can be replaced with a generic ground. basically, there is a ground with a pit in it, and we want people to have the view of falling into the pit. i'd also like to have them pop back up when they get out of the range of the pit. it works fine on keyboard control but not when using the tracker:
import time
import math
import random
import winsound
ground = viz.add('Models/ground_2m.ive')
pit = viz.add('Models/ground_pit_new.ive')
#Select this for single-monitor desktop use...
#viz.go(viz.FULLSCREEN)
#OR select these for HMD/dual-monitor use:
viz.go(viz.STEREO | viz.FULLSCREEN)
light1 = viz.addLight() #Add an overhead light
light1.setEuler(0,90,0)
## Prompt for the participant's identification number - generally keep this uncommented! ##
keyControl = viz.input('Using Tracker? 1 = Yes, 2 = No')
#subject = viz.input('What is the participant number?')
if keyControl == 1:
eyeohd = viz.input('What is the participants IOD?')
#HMD field of view: (vert. FOV, aspect ratio H:V)
#viz.fov(53,1.1887) #Kaiser SR80 specs
viz.fov(43,1.395) #Cybermind specs
##Rename the main view ##
view = viz.MainView
#Link viewpoint with tracker, initialize boresite
if keyControl == 1: #If you're using the tracker
headTrack = viz.addSensor('intersense')#Ignore documentation stating you need "intersense.dls" - this is correct
linkedTracker = viz.link(headTrack, view) #Link the sensor to the view.
linkedTracker.preTrans([0,-.15,.14]) #Boresite function - translates the viewpoint from the tracker position to eyepoint position
# viz.link(headTrack, view) #Link the sensor to the view.
viz.eyeheight(0.0)
view.translate(0,-.19,.14) #Boresite function - translates the viewpoint from the tracker position to eyepoint position
viz.ipd(eyeohd/100.0)
#Initialize parameters for keyboard control
MOVE_SPEED = 1.3 #m/s
TURN_SPEED = 60 #deg/s
#NOTE: Default eye height for keyboard control is 6', doesn't affect tracked viewpoint
viz.phys.enable() # Enable physics
viz.MainView.gravity (0)
#This turns mouse control of view and mouse pointer off - very disconcerting for subjects!
# Generally keep both viz.OFF, unless you have a specific need.
viz.mouse(viz.OFF)
viz.cursor(viz.OFF)
Risen = True
global Risen
riseAction = vizact.fall(1.82)
if view.getPosition(mode=viz.ABS_GLOBAL)[0] > -1 and view.getPosition(mode=viz.ABS_GLOBAL)[0] < 1:
if view.getPosition(mode=viz.ABS_GLOBAL)[2] > 5.375:
Risen = False
elif view.getPosition(mode=viz.ABS_GLOBAL)[2] < 4.625 and view.getPosition(mode=viz.ABS_GLOBAL)[2] > -1.625:
Risen = False
elif view.getPosition(mode=viz.ABS_GLOBAL)[2] < -2.375:
Risen = False
view.add(riseAction)
Risen = False
print 'back up'
elif (view.getPosition(mode=viz.ABS_GLOBAL)[0] < -1 or view.getPosition(mode=viz.ABS_GLOBAL)[0] > 1) and Risen == False:
Risen = True
print 'normal view'
###### KEYBOARD CONTROL MODULE - DON'T TOUCH ######
if keyControl == 2: #If you're using the keyboard; defined at top
if viz.iskeydown(viz.KEY_UP): #If the up key is depressed
view.move(0,0,MOVE_SPEED*viz.elapsed(),viz.BODY_OR I) # Move view to z coordinate specified by speed*elapsed time
elif viz.iskeydown(viz.KEY_DOWN): #And so on and so forth
view.move(0,0,-MOVE_SPEED*viz.elapsed(),viz.BODY_ORI)
if viz.iskeydown(viz.KEY_RIGHT):
view.rotate(0,1,0,TURN_SPEED*viz.elapsed(),viz.BOD Y_ORI,viz.RELATIVE_WORLD)
view.rotate(0,1,0,-TURN_SPEED*viz.elapsed(),viz.BODY_ORI,viz.RELATIVE _WORLD)
#This starts the timer. First value (0) is a timer identifier, second (1/60) is the refresh rate, third (viz.FOREVER) is how long it lasts
Old 02-28-2008, 02:01 PM
You need to post the code using the [code][/code] tags. This will preserve the indentation, which is necessary for running Python code.
Old 03-01-2008, 11:03 AM
sorry, i'm new to this format so i thought it would preserve the tabs that were in place. here's the code again:
import time
import math
import random
import winsound
if keyControl == 1:
view = viz.MainView
viz.eyeheight(0.0)
viz.mouse(viz.OFF)
viz.cursor(viz.OFF)
Risen = True
global Risen
Risen = False
Risen = False
Risen = False
Risen = False
Risen = False
print 'back up'
Risen = True
print 'normal view'
Old 03-03-2008, 12:54 PM
I get a syntax error when trying to run your code. It doesn't seem like you used the [code][/code] tags. Just copy the contents of your script and paste them in between the tags.
Old 03-03-2008, 09:09 PM
are there additional tags to indicate that the code is starting and ending? they are not clearly marked in any of the message options.
import time
import math
import random
import winsound
if keyControl == 1:
view = viz.MainView
    viz.eyeheight(0.0)
viz.mouse(viz.OFF)
viz.cursor(viz.OFF)
Risen = True
    global Risen
        Risen = False
        Risen = False
        Risen = False
        Risen = False
        Risen = False
        print 'back up'
        Risen = True
        print 'normal view'
Old 03-04-2008, 06:56 AM
here is the code that should have all the tabs in the right place
import time
import math
import random
import winsound
if keyControl == 1:
view = viz.MainView
    viz.eyeheight(0.0)
viz.mouse(viz.OFF)
viz.cursor(viz.OFF)
Risen = True
    global Risen
			Risen = False
			Risen = False
			Risen = False
			Risen = False
			print 'back up'
        Risen = True
        print 'normal view'
            view.move(0,0,MOVE_SPEED*viz.elapsed(),viz.BODY_ORI) # Move view to z coordinate specified by speed*elapsed time
            view.rotate(0,1,0,TURN_SPEED*viz.elapsed(),viz.BODY_ORI,viz.RELATIVE_WORLD)
            view.rotate(0,1,0,-TURN_SPEED*viz.elapsed(),viz.BODY_ORI,viz.RELATIVE_WORLD)
Old 03-04-2008, 06:57 AM
again note that i've put in a model just so that i can tell where i am in the world, can be replaced with any generic ground plane.
Old 03-04-2008, 09:57 AM
I just ran your script using an Intersense InertiaCube2 and it ran fine. What kind of Intersense device are you connecting to?
Old 03-05-2008, 08:11 AM
we have an intersense IS900. i tried it again making sure that all the vizard software is up-to-date and it's still not working. it is just fine with the keyboard, however.
Old 03-06-2008, 09:47 AM
Can you post the entire output of your script, not just the last error. The error message you posted earlier implies that another error occurred before that one. It would make it easier to determine what is causing the problem.
Old 04-25-2008, 07:30 AM
i am run it again after updating to the latest edition to vizard, and now it does not give me any error messages at all. however, it is still not creating the visual fall when i hook it up to the HMD and tracker (is900), even though it works on keyboard mode. it is definitely detecting that it is in the right location because it prints "in pit" in the appropriate location. could it be that the viewpoint is bound to the physical location of the tracker and so it won't fall?
import time
import math
import random
import winsound
if keyControl == 1:
view = viz.MainView
    viz.eyeheight(0.0)
viz.mouse(viz.OFF)
viz.cursor(viz.OFF)
Risen = True
    global Risen
			print 'in pit'
			Risen = False
			print 'pit 2'
			Risen = False
			print 'pit 3'
			Risen = False
			Risen = False
			print 'back up'
        Risen = True
        print 'normal view'
Old 04-28-2008, 12:57 PM
Yes, the problem is that you are linking the viewpoint to the tracker location, which will override any translations made by the fall action. You will need to apply the fall action to a dummy node and transfer the position of the dummy node to the viewpoint as an offset. I've made the changes to your script that implement this, and it should work correctly now.
import time
import math
import random
import winsound
pit = viz.add('ball.wrl')
if keyControl == 1:
#Dummy node for falling
fallNode = viz.addGroup()
riseAction = vizact.fall(0)
view = viz.MainView
	tracker = viz.addSensor('intersense')#Ignore documentation stating you need "intersense.dls" - this is correct
	viz.eyeheight(0.0)
	import viztracker
	tracker = viztracker.Keyboard6DOF(forward=viz.KEY_UP,backward=viz.KEY_DOWN,turnRight=viz.KEY_RIGHT,turnLeft=viz.KEY_LEFT)
linkedTracker = viz.link(tracker, view) #Link the sensor to the view.
linkedTracker.postMultLinkable(fallNode,mask=viz.LINK_POS)
viz.mouse(viz.OFF)
viz.cursor(viz.OFF)
Risen = True
	global Risen
	if view.getPosition(mode=viz.ABS_GLOBAL)[0] > -1 and view.getPosition(mode=viz.ABS_GLOBAL)[0] < 1 and Risen == True:
			fallNode.addAction(fallAction)
			print 'in pit'
			Risen = False
			print 'pit 2'
			Risen = False
			print 'pit 3'
			Risen = False
			fallNode.addAction(riseAction)
			Risen = False
			print 'back up'
		Risen = True
		print 'normal view'
Old 06-11-2008, 02:24 PM
thanks, it worked!
