Old 02-04-2008, 04:15 PM
tbowden tbowden is offline
simultaneous movement of limbs
Does anybody know how to program the limbs and joints of avatars to move simultaneously with no wait time in between?
Old 02-04-2008, 06:30 PM
I'm not clear on what you are asking. Do you want to animate the bones of an avatar manually? Or do you want to run two animations simultaneously?
Old 02-07-2008, 07:28 AM
Re:
Im actually manipulating the bones manually but it seems so far that I can't get two different bones to move at the same time, although I have thought recently about using the parallel function or maybe using different pools.
Old 02-07-2008, 09:44 AM
This is most likely a problem with your script. Can you post some sample code showing how you are trying to move to limbs simultaneously?
Mouse/Keyboard Movement joeymax Vizard 1 04-02-2007 10:43 AM
Lip movement threshold susan Vizard 5 05-25-2006 04:13 PM
eye movement epl Vizard 1 06-04-2004 12:29 PM
avatar bone movement epl Vizard 3 05-03-2004 04:27 PM
movement problems keastman Precision Position Tracker (PPT) 1 09-09-2003 11:41 AM
