Old 02-04-2008, 11:13 AM
wouters wouters is offline
Question Texture Path
I have been trying to load some collada files into Vizard. The actual geometry loads just fine, but the textures aren't being loaded because for some reason Vizard is adding an initial / to the texture path name. For example the real path to the texture is R:/vissim/data/models/3105Model/3105-model-changed-35/pillar.jpg
but Vizard is trying to load
/R:/vissim/data/models/3105Model/3105-model-changed-35/pillarTexture.jpg
Is there anyway that I can keep this from happening?
Thanks for your help!
Leah
Old 02-04-2008, 07:40 PM
This is probably a bug in the Collada plugin. Can you send me a sample file at lashkari@worldviz.com ?
Old 04-03-2009, 06:18 AM
omidbrb omidbrb is offline
I'm also having this problem. Is there any solution for it?
Omid
Old 04-06-2009, 12:56 PM
Can you send a sample file to support@worldviz.com?
Old 09-24-2009, 11:42 AM
pcatalano pcatalano is offline
Lightbulb Temporary fix is to put textures in same directory as your script
I had this same issue. I temporarily resolved it by placing the textures in question in the same directory as my vizard python script.
Skydome texture problem theuberk Vizard 2 01-18-2008 06:56 AM
missing parts of head texture sjp Vizard 4 10-10-2006 02:10 PM
how I can get my texture to appear exactly as is defined mspusch Vizard 1 04-23-2005 01:12 PM
avatar head texture issues rconrey Vizard 3 11-17-2004 05:05 PM
How to simply texture an avatar's head with a jpeg graphic? vr_boyko Vizard 3 10-26-2004 11:44 AM
