Old 01-29-2008, 06:14 AM
theuberk theuberk is offline
multiple shadows using projector
I'm trying to create multiple shadows using the projector module. It seems however that only one projected can exist at one time. For example, the following code only produces one shadow (proj2):
enviro = viz.add('C:\\Program Files\\WorldViz\\Vizard30\\resources\\tut_ground.wrl')
image1 = viz.add('cars\\carShadow.png')
image2 = viz.add('cars\\carShadow2.png')
proj1 = projector.add(image1)
proj1.translate(0,0,0)
proj1.rotate(0,90,0)
proj1.affect(enviro)
proj1.ortho(2,2)
proj2 = projector.add(image2)
proj2.translate(6,0,0)
proj2.rotate(0,90,0)
proj2.affect(enviro)
proj2.ortho(2,2)
Any help would be greatly appreciated.
Old 01-29-2008, 07:36 PM
You need to apply the second projection texture to a different texture unit. Try the following code:
import projector
enviro = viz.add('tut_ground.wrl')
image1 = viz.add('eyeshadow.jpg')
image2 = viz.add('eyeshadow.jpg')
proj1.translate(1,0,10)
proj1.affect(enviro) #Apply projection texture to default texture unit 1
proj1.ortho(2,2)
proj2.translate(-1,0,10)
proj2.affect(enviro,2) #Apply projection texture to texture unit 2
proj2.ortho(2,2)
Old 01-30-2008, 08:02 AM
Perfect thanks! I didn't see anything about texture units in the documentation.
Old 01-30-2008, 08:13 AM
I tried that out but it only seems to work for up to 3 shadows. I need it to work for up to 20 or so. Is this possible?
Old 01-30-2008, 09:28 AM
The limit depends on your graphics cards. Some graphics cards support only 4 texture units. Some newer cards can support up to 16.
Old 01-31-2008, 08:24 AM
I checked the specs on the graphics cards I'm using (2 x 8800GTS - 512MB in SLI), and numerous sources say that there are 64 texture mapping units on these cards. After reading THIS FORUM THREAD, I'm suspecting it may be an OpenGL problem, however I'm not sure at all. Any ideas what the problem might be?
Old 02-01-2008, 10:29 AM
I believe OpenGL has a limit of 4 texture units when using the fixed function pipeline, which is what the projector plugin uses. To use more texture units you would have to use shaders for projecting the texture onto a model. There is a description about it on nVidias website.
Old 02-05-2008, 01:44 PM
Is there a better way than the projector plugin to implement shadows in vizard?
Old 02-06-2008, 07:19 PM
Click here for a post that contains an example of dynamic projected shadows. It works reasonably well as long as the shadow casting objects are contained in a small area.
Old 01-30-2009, 07:08 AM
omidbrb omidbrb is offline
I used the example provided in this thread, but with multiple avatars. Still only 3 avatars have shadows. Is there any demo that is not relying on the projector plugin?
Omid
Old 02-05-2009, 01:41 PM
When you used the shadow module were all your avatars contained within the area defined by your SHADOW_AREA value. You can increase that value but then the resolution of the shadows will not be as sharp. You can then also increase the resolution of the shadows but that will use up more texture memory.
Old 02-06-2009, 02:08 AM
But one should make a seperate Shadow.ShadowProjector objects for each avatar. Hence, as I get, SHADOW_AREA is not the area that all the shadows should be contained in, rather it represents a box that each shadow should fit in. Please correct me if I'm wrong.
I suspect that because ShadowProjector is using the projector module in wizard and the projector module is limited by OpenGL's limit of 4 textures on a surface, only 3 avatar shadow textures + the surface's own texture is being applied.
Do you know of any alternatives?
Best,
Omid
Old 02-06-2009, 09:41 AM
Here's a few more avatars added to the shadow example. SHADOW_AREA is set to 10,10 and SHADOW_RES is set to 512 to maintain sharp shadows. Are you able to get 5 shadows here?
#Add ground model
#Add avatars
avatar = viz.add('vcc_female.cfg',pos=(-4,0,12),euler=(180,0,0))
avatar2 = viz.add('duck.cfg',pos=(-2,0,12),euler=(180,0,0))
avatar3 = viz.add('vcc_male.cfg',pos=(0,0,12),euler=(180,0,0))
avatar4 = viz.add('male.cfg',pos=(2,0,12),euler=(180,0,0))
avatar5 = viz.add('female.cfg',pos=(4,0,12),euler=(180,0,0))
avatar.state(5)
avatar2.state(1)
avatar3.state(7)
avatar4.state(9)
avatar5.state(5)
#Shadow resolution (power of two)
#Higher values mean sharper shadows, but take more texture memory
SHADOW_RES = 512
#Postion of shadow projector
SHADOW_POS = [0,10,12]
#Controls size of orthographic shadow projector
#Large values mean larger area is covered, but resolution will be diluted
SHADOW_AREA = [10,10]
#Create shadow projector
import Shadow
shadow = Shadow.ShadowProjector(size=SHADOW_RES,pos=SHADOW_POS,area=SHADOW_AREA)
#Add avatar as a shadow caster
shadow.addCaster(avatar)
shadow.addCaster(avatar2)
shadow.addCaster(avatar3)
shadow.addCaster(avatar4)
shadow.addCaster(avatar5)
#Add ground as shadow receiver
shadow.addReceiver(ground)
Old 02-24-2009, 02:56 AM
Yes it worked. Thanks. My misunderstanding was that I thought SHADOW_POS and SHADOW_AREA refers to the shadow itslef.
Shadows in Vizard Vinicius Lima Vizard 4 07-26-2010 05:56 PM
3d projector Vinicius Lima Vizard 21 03-05-2008 03:51 PM
Multiple labs Plymouth Vizard 1 03-05-2007 09:43 AM
Multiple Stages in one Program Amit Vizard 7 11-11-2005 10:20 AM
multiple timer trouble exhale Vizard 2 04-26-2005 12:21 AM
