Old 01-09-2008, 06:39 AM
krimble krimble is offline
animate cal3d bones
Hi all,
What I have is a cal3d avatar with a peoplemaker morph (for a talking mouth).
The avatar has to perform an animation: lean forward - back the origin - lean backward back to origin - lean left - back to origin - lean right and back to origin.
The bone that I want to rotate is one of the spineBones.
This is the code-part where i'm talking about:
viz.starttimer(TIMER_BODY_MOVEMENT, .03, 1)
def onTimerEvent(id) :
if id == TIMER_BODY_MOVEMENT :
    spine02.rotate(10,0,0)
viz.callback(viz.TIMER_EVENT,onTimerEvent)
What's happening now: the bone seems to snap to the new position, with <bone>.setEuler() it's doing the same.
How can I make this a smooth animation?
cal3d exporter issue reiverlass Vizard 4 07-18-2007 01:08 PM
importing avatars with cal3d marcoleon Vizard 15 04-28-2006 05:48 PM
importing cal3d in 3ds? shai Vizard 1 11-01-2004 11:19 AM
Using Cal3d Avatars zachhendershot Vizard 4 01-27-2004 11:26 AM
Linking avatar 'bones' to a position tracker. zachhendershot Vizard 3 11-19-2003 10:26 PM
