Old 09-13-2007, 05:38 PM
k_iwan k_iwan is offline
Unhappy Avatar facial animation.... [suggestions needed]
Hi All,
Could I get a suggestion? What is the best way to do facial animation with speech in vizard?
[A] Should I create morph targets for every phonemes? A, I, U, E, O shapes, etc?, and later on use vizard to morph it based on .wav file?
i.e. How are you today?
becomes; A morph -> E morph -> OO morph -> U morph quickly into -> E morph?
[B] any other alternatives?
Old 09-18-2007, 04:59 PM
You will definitely need to create a morph for each basic phoneme. However, Vizard doesn't currently have any way to parse a wav file and generate the phoneme sequence for you. I believe there are some libraries out there that can compute this, otherwise you will have to manually create the phoneme sequence yourself. You can then manually animate the morphs within a timer or use a sequence of vizact.morph actions.
