Old 08-23-2007, 01:18 PM
Jerry Jerry is offline
Intersense reset
According to the help documentation, if I do
ori = viz.add('intersense.dls')
ori.command(2)
ori.get() should come back 0,0,0 for yaw, pitch, and roll, but this
does not happen.
Is there something I'm missing or is this a bug?
Old 08-23-2007, 01:42 PM
The command you are issuing will perform all subsequent resets in a local reference frame. You will have to issue a reset() command afterwards and wait a frame for the intersense data to be updated.
Old 08-28-2007, 10:31 AM
That still doesn't work. If I do this:
ori.command(2)
ori.reset()
print ori.get()
the values of yaw, pitch, and roll are not equal to zero.
What I want to do is zero all three axes.
Old 08-28-2007, 01:00 PM
Are you waiting a frame so the intersense data is updated before issuing the reset command?
Old 08-28-2007, 01:10 PM
Yes. I have reset() and command() assigned to different
keys. I press the command() key and then, after waiting for
what must be longer than one frame, I press the reset() key.
Old 08-28-2007, 02:32 PM
Sorry, I forgot to mention that these reset modes only work when the intersense is in quaternion mode. After adding the intersense you will need to issue the following command:
isense.quat()
Also, the built-in link objects already support these reset modes. I would recommend using them since it is independent of the actual hardware. Here is an example script that shows how to use the different link reset modes with an intersense:
#Add ground
#Add intersense
PORT_INTERSENSE = 1
isense = viz.add('intersense.dls')
#Add node
node = viz.add('marker.wrl')
node.translate(0,1.5,4)
viz.startlayer(viz.LINES)
viz.vertexcolor(viz.RED)
viz.vertex(0,0,0)
viz.vertex(0,0.5,0)
viz.endlayer(parent=node)
#Link sensor to node
link = viz.link(isense,node)
#Create keyboard events
vizact.onkeydown('r',isense.reset)
vizact.onkeydown('1',link.reset,viz.RESET_ORI_LOCAL)
vizact.onkeydown('2',link.reset,viz.RESET_ORI_WORLD)
vizact.onkeydown('3',link.reset,viz.RESET_ORI_RAW)
