Thread Tools Rating: Thread Rating: 67 votes, 5.00 average. Display Modes
Old 08-14-2007, 04:46 AM
krimble krimble is offline
Maya + cal3d
Does anyone know how to name the materials in Maya for cal3d export. You have to name them sequentially "mat[0], mat[1], etc". In 3dsmax you can use the "[]" but Maya can't work with the "[]" characters. When I type "[]" maya creates "_ _".
I've found an article where they say that those underscores are fine to use for the material names.
But when I try to export for example the head mesh, I get the message
"invalid material ID found! (\dev\vizard30\cal3d\plugins\src\meshcandidate.cpp 172)".
how can I solve this, it saves me soooo much time when I don't have to use 3ds max.
Thanks!!
Old 08-15-2007, 07:51 AM
problem solved, you can use "_ _" in maya. But you have to use "export selection" instead of "export all".
Next problem
Now I've exported all the parts (skeleton, meshes, textures), created a configFile. It was all going very smooth, but when I loaded the configFile into Vizard and ran the script, a error message appeared.
cal3d : Invalid handle as argument in skeleton.cpp(103)
Model::create: ERROR: Can't create a m_model. Most probable reason is that the core doesn't have any data.
What's that??
There're no mistakes in the configFile, I've checked it 10 times! When I open the csf file with a texteditor, I get some text, so there's data in the file...
Please, it saves me so much time when I don't have to export it in 3dsmax.
thanks..
