Old 08-01-2007, 09:57 AM
Vinicius Lima Vinicius Lima is offline
vizact
HI.
I'm going over the Vizard tutorials to practice my VR skills and I ran into this problem. The tutorial told me this info and I tried to fix using the vizact.goto, but the script did not work. Can you send me a sample of a script where that argument is used?
** WARNING: <node>.goto will be deprecated in future versions of Vizard, use vizact.goto instead
Vinicius
Old 08-01-2007, 02:10 PM
The warning message means you should change code that looks like this:
node.goto(...)
to this:
node.add( vizact.goto(...) )
