Old 07-02-2007, 03:53 PM
Jerry Jerry is offline
VizMenu aspect
When I run a script which uses vizMenu in STEREO | HMD mode the aspect ratio of the menu is distorted such that it is stretched vertically so that radio buttons are oblong instead of round. Can this be fixed? The 3D scene objects appear normal.
Also, when running in STEREO mode, the mouse can't be used to select a menu since as the mouse pointer moves across the entire stereo display but the highlighted menu moves across only the field for one eye, i.e., half the stereo display.
Old 07-09-2007, 11:59 AM
There is no solution to this currently. It will be fixed in the next release though.
