Old 04-13-2007, 04:16 AM
ghazanfar ghazanfar is offline
smiling
hi,
i am using headmorphing for smiling, at every time point i am giving different value for smiling, but it always shows the same setting as it made at 1st time point.
how can i see the smiling face depending upon the different values, so that every time it will give me real impression.
problem is that, it does not change the smiling face to normal.
awaiting for reply
Old 04-13-2007, 12:11 PM
Can you post the code you are using to set the morph? If you want to set the smile to 10% you would do something like this:
face.morph(1,0.1) #Assuming smile morph number is 1
To put the smile to 100% you would do this:
face.morph(1,1.0)
