Trouble with vizact.speak()
When I use the speak action, the avatar's mouth moves but there's no audio. It had been working for me except with the avatar's actions being a bit glitchy. I subbed in JFK.wav to see if it would glitch and it didn't but since I've gone back to the original file, the audio won't play. Is this a known bug?
Could you post the code that is causing the problem? I think I've had a similar problem, also experienced avatars acting a bit glitchy, but that could be due to the speak action.
Strangely enough it started working with some other .wav files and I've not had problems with it since. So I'm not entirely sure what the problem was.
Try setting sync=True as speak() argument
Trouble using custom animations for Live Characters | IGoudt | Vizard | 0 | 09-24-2009 06:37 AM |
trouble tracking multiple lights | Vkathrynr | Precision Position Tracker (PPT) | 2 | 08-26-2009 12:07 PM |
Trouble transitioning from one vizard | DBurks2818 | Vizard | 3 | 04-28-2009 02:46 PM |
trouble changing subnode (child node) color, alpha, etc. | michaelrepucci | Vizard | 7 | 01-14-2009 08:38 PM |
multiple timer trouble | exhale | Vizard | 2 | 04-26-2005 12:21 AM |
