Old 03-29-2010, 02:31 PM
c4am95 c4am95 is offline
Title Screen
For some reason I've had some trouble doing something that should be fairly easy. Before rendering the world, I want a really simple title screen to pop up, eg a colored screen with some text. When the user is ready, eg some key is pressed, that screen disappears and the world begins rendering. I'm new to vizard (and haven't done a ton of graphics), so I don't know what the best way to do this is. So...let's talk about it huh? Please?
Old 03-29-2010, 03:59 PM
If you want a simple title screen you can set the background color and add some text to the screen. When the user hits a key you can remove the text and render the world.
gallery.visible(viz.OFF)
viz.clearcolor(viz.SKYBLUE)
text = viz.addText('Title Screen', parent = viz.SCREEN)
text.setPosition(0.3,0.5)
def showWorld():
	gallery.visible(viz.ON)
	text.remove()
	viz.clearcolor(viz.BLACK)
vizact.onkeydown(' ',showWorld)
If you wanted to show an image for the title sceen the following knowledge base article describes how to replace the background color with an image.
http://kb.worldviz.com/articles/813
Old 03-30-2010, 01:05 PM
thanks for your reply. i'm assuming that "gallery" is an environment model or something right? so basically this code would set the visibility of everything in the world off initially, and upon user input turn the visibility of those objects back on? so you would have to do this for every single world object? if so, i was kind of looking for a solution that avoided that. i just thought perhaps there was a way to disable all world rendering that didn't disable 2d text rendering. if not, though, this method isn't tough.
Old 03-30-2010, 01:30 PM
If you want to hide the entire scene then you can use the following code:
viz.MainScene.visible(0,viz.WORLD) #Hide all objects in world
viz.MainScene.visible(1,viz.WORLD) #Unhide all objects in world
Old 04-08-2010, 02:24 PM
thanks for your help. that'll work. i didn't know about multiple scenes so now i understand much better.
split screen honey006 Vizard 3 05-21-2009 10:57 AM
Remove the credits on the run screen Saz Vizard 1 11-21-2008 10:01 AM
screen image erchrastil Vizard 8 06-27-2008 12:45 PM
position of html-file on screen active_world Vizard 1 05-16-2008 08:24 PM
accessing screen buffer hotspur1 Vizard 3 08-22-2003 04:31 PM
