Old 01-18-2010, 09:37 PM
wchoi wchoi is offline
How to make character animation sequence
Dear admin
code:
female = viz.add('vcc_female.cfg', pos = [0,0,5], euler = [90,0,0])
female.state(7) # jump forward
female.state(6) #fight
female.state(7) #jump forward
We would like to make a sequence of character animation such as
jump forward, fight and jump forward.
But female.state(7) is returned at first frame after last frame of jump forward.
It is problem to make character animation.
So,
#female.execute(7, freeze = True)
can pause last frame. But, we can not connect smoothly next motion(female.state(6)).
We want to connect next motion at the position of last frame of first motion.
Please know me how to resolve this problem.
Best regards,
choi
Old 01-19-2010, 10:02 AM
The state method has an optional delay argument to specify how long it will take to fully blend in the new state and blend out the old one to give a smooth transition. In the following, press the spacebar and after 2 seconds animation 5 will be blended in.
male = viz.add('vcc_male.cfg', pos = [0,0,5], euler = [180,0,0])
male.state(1)
vizact.onkeydown(' ', male.state,5,2)
Old 01-19-2010, 05:37 PM
Dear Jeff
We made the code to connect the next motion at the position of last frame of first motion.
Please check the code and give me the comment.
code:
viz.clearcolor(viz.SKYBLUE)
#Position avatar in view
avatar = viz.add( 'vcc_male.cfg' )
avatar.setPosition( 0, 0, 20 )
avatar.setEuler( 90, 0, 0 )
#Create an action to fade out in 5 seconds
#fadeOut = vizact.fadeTo(0,time=5)
#Add the ground plane
viz.add('tut_ground.wrl')
#Create an action to move to location (0,1,0) at 5 m/s
#Add the fade out action to the node
#avatar.addAction(fadeOut)
#Add the moveTo action to the node
#It won't start until the fade out action completes
avatar.addAction( vizact.animation(7,2.685,0.1,0) )
moveTo = vizact.moveTo([1.8,0,20],speed=900000000000000000000000000000)
avatar.addAction(moveTo)
avatar.addAction( vizact.animation(6,2.685,0.1,0) )
#moveTo1 = vizact.moveTo([3.6,0,20],speed=90000000000000000000000000000)
#avatar.addAction(moveTo1)
moveTo2 = vizact.moveTo([3.6,0,20],speed=90000000000000000000000000000)
avatar.addAction(moveTo2)
avatar.addAction( vizact.animation(10,2.685,0.1,0) )
#moveTo3 = vizact.moveTo([7.2,0,20],speed=90000000000000000000000000000)
#avatar.addAction(moveTo3)
Best regards,
choi
Old 01-22-2010, 08:35 AM
If you want the avatar to move to a position immediately after an animation has completed you can leave out the speed argument in the vizact.moveTo command and it will work the same.
animation sequence Andy Vizard 1 10-01-2009 10:42 AM
character animation nlfrnassimi Vizard 3 03-11-2009 02:46 PM
Native WorldViz support for character animation luakt Vizard 10 09-15-2008 11:39 PM
animation sequence pkhoosh Vizard 2 01-23-2006 08:03 AM
animation sequence shai Vizard 1 10-27-2004 10:09 AM
