Old 12-19-2009, 07:06 PM
srwing srwing is offline
How to use precipitation.dle?
I was wondering if anyone has any information about the precipitation.dle file in the Vizard plug-ins directory? I can not find any documentation on the use of this file and am wondering how to use it effectively and/or what kind of settings are available.
This is what I have so far :
precip = viz.add('precipitation.dle')
snow = precip.snow(1) #Create snow with intensity of 1
snow.setSpeed(0.0001)
Old 12-21-2009, 11:20 AM
After adding the plug-in you can either create a snow or rain object from that. Each one has methods that allow you to set the size, speed, and wind for the particles. Here is a sample script that you can use to change the effects.
viz.add('tut_ground.wrl')
import vizmenu
menu = vizmenu.add()
OptionsMenu = menu.add('Options')
SpeedSlider = OptionsMenu.add(viz.PROGRESS_BAR,'Default','Speed')
SizeSlider = OptionsMenu.add(viz.PROGRESS_BAR,'Default','Size')
WindSlider = OptionsMenu.add(viz.PROGRESS_BAR,'0.00','Wind')
WindSlider.set(0.5)
def onSpeed(pos):
	val = pos*10
	snow.setSpeed(val)
	SpeedSlider.message('%.2f'%(val))
vizact.onslider(SpeedSlider,onSpeed)
def onSize(pos):
	val = pos*0.1
	snow.setSize(val)
	SizeSlider.message('%.2f'%(val))
vizact.onslider(SizeSlider,onSize)
def onWind(pos):
	val = pos*20 - 10
	snow.setWind([val,0,0])
	WindSlider.message('%.2f'%(val))
vizact.onslider(WindSlider,onWind)
