Old 10-12-2009, 09:25 PM
james007 james007 is offline
Navigating an avatar using mouse position(2D) in 3D environment
I am trying to navigate an avatar using mouse e.dx and e.dy position in 3D environment.
Could you give any idea to how use e.dx and e.dy to solve the problem?
James
(on viz.MOUSE_MOVE_EVENT event, I am having e.dx and e.dy
e.dx
The relative movement of the mouse in the X direction. The value is in raw mouse units. Negative values indicate the mouse was moved to the left. Positive values indicate the mouse was moved to the right.
e.dy
The relative movement of the mouse in the Y direction. The value is in raw mouse units. Negative values indicate the mouse was moved downward. Positive values indicate the mouse was moved upward.
Old 10-16-2009, 11:29 AM
Can you be more specific in how you want to control the avatar? Do you want a First-person-shooter type control? Have you looked at the Viewpoint control tutorial?
avatar scale and link.setpos conflict? sircedric4 Vizard 0 09-29-2009 07:48 AM
Collision of an avatar with a quad Frank Verberne Vizard 8 06-04-2008 09:44 AM
Looking through the eyes of an avatar Frank Verberne Vizard 2 04-01-2008 05:52 AM
Getting a mirror to work in any environment Frank Verberne Vizard 5 03-27-2008 08:21 AM
How to make avatar's eyes to blink when speaking michelcm3 Vizard 12 01-15-2008 08:48 AM
