Old 05-05-2009, 09:56 AM
durf durf is offline
Physics Question
Im trying to have a ball fall from a certain height and pass through a floor but have it land on the floor below it. Can anyone explain what I am doing wrong?
viz.phys.enable()
viz.MainView.setPosition([0,10,-35]) #sets camera position
viz.MainView.setEuler([0,2,0]) #sets camera pitch
ground1 = viz.add('tut_ground.wrl')
ground1.disable(viz.PHYSICS)
ground2 = viz.add('tut_ground.wrl')
ground2.setPosition([0,-2,0])
ground2.collidePlane()
ball = viz.add('ball.wrl',pos=[0,15,6]) # Add a ball
ballPhys = ball.collideSphere() # Enable physics on ball
Old 05-05-2009, 11:30 AM
Moh200jo Moh200jo is offline
your ground has a collision plane around. I correct you have to remove this line from your code, and then the ball will be passing through the ground.
hope this helped you!
Old 05-06-2009, 01:07 PM
You need to specify that the collide plane is at y = -2 to match the y coordinate of ground2
ground2.collidePlane(0,1,0,-2)
physics engine exception ad_astra Vizard 3 03-25-2009 11:31 AM
Physics and Haptics jalvarez Vizard 3 07-16-2008 03:03 PM
another physics question adimov Vizard 1 07-22-2004 03:56 PM
Physics engine question adimov Vizard 2 07-22-2004 12:33 PM
