Old 07-30-2004, 11:08 AM
You can run a vizard script from any programming environment. All you need to do is execute the following in the command line:
"C:\Program Files\Vizard20\bin\winviz.exe" "script.py" 0
The way to do this is different for each programming language, so you will have to look at the documentation for it. Here's an example of how to do it in python, however I don't recommend launching a vizard script within another vizard script.
import win32process
def startscript(filename):
	execCommand = viz._BIN_PRIMARY + ' "' + filename + '" 0'
	win32process.CreateProcess(None, execCommand,
								  None, None, 1, 0, None,
								  None, win32process.STARTUPINFO())
startscript('myscript.py')
