Old 01-27-2009, 09:42 PM
try using the viz.screentoworld function to get a line that you can use to call viz.intersect. This code should let you know if the pointer is in line with an object
def FireLine():
	line = viz.screentoworld(pointer.getPosition())
	dir = viz.Vector(line.dir)
	dir.setLength(200)
	begin = line.begin
	end = line.begin + dir
	info = viz.intersect(begin,end)
	if info.valid:
		print "intersected"
vizact.onsensordown(wiimote,wii.BUTTON_B,FireLine)
Strange Wii Mote error... shivanangel Vizard 8 02-18-2009 12:32 PM
vizinfo + wiimote ? djdesmangles Vizard 6 10-22-2008 02:18 PM
Sending sound to Wiimote ? djdesmangles Vizard 1 07-31-2008 11:26 AM
wiimote and sensor bar masaki Vizard 1 03-06-2008 03:07 PM
