Old 01-27-2009, 08:25 PM
AlyssaK AlyssaK is offline
set mouse position
Hi all,
I would like to know if its is possible to set the mouse position???
I found the method viz.mousepos and have assigned it the value of the wiimote coordinates however the cursor does not move.
If you can help please post a response.
ALyssa
Old 01-28-2009, 04:05 PM
The following script shows how to use a wiimote to control the mouse movement and simulate mouse button presses:
import win32api
import win32con
#Create wii extension
wii = viz.add('wiimote.dle')
#Connect to wiimote
wiimote = wii.addWiimote()
if not wiimote.valid():
	sys.exit()
#Use wiimote button B to simulate left mouse click
def SimulateMouseButton(button):
	win32api.mouse_event(button,0,0,0)
vizact.onsensordown(wiimote,wii.BUTTON_B,SimulateMouseButton,win32con.MOUSEEVENTF_LEFTDOWN)
vizact.onsensorup(wiimote,wii.BUTTON_B,SimulateMouseButton,win32con.MOUSEEVENTF_LEFTUP)
#Use wiimote IR sensor position to simulate mouse movement
def SimulateMouseMove():
	x,y = wiimote.posIR
	win32api.mouse_event(win32con.MOUSEEVENTF_ABSOLUTE|win32con.MOUSEEVENTF_MOVE,int(65535*x),int(65535*(1.0-y)),0)
vizact.ontimer(0,SimulateMouseMove)
writing joystick position to a data file Saz Vizard 3 12-17-2008 05:18 AM
default start position erchrastil Vizard 2 06-23-2008 08:15 AM
Avatar always returns in initial position pattie Vizard 2 08-31-2006 08:15 PM
Mouse problem steve Vizard 7 07-14-2005 03:01 PM
Halting mouse view-transforms FlyingWren Vizard 1 10-01-2003 05:29 PM
