Old 10-17-2008, 06:05 PM
Is using threading.Threads objects possible while running a Vizard sim without the viz.directormode call? In other words, must you set the director mode when you want to run threading.Threads while running a Vizard sim?
Paul Elliott
WorldViz LLC
Old 10-17-2008, 06:16 PM
It depends. The call to viz.directormode(viz.DIRECTOR_FAST) simply tells Vizard to allow other Python threads to run while it is rendering. If you don't have this flag set, then the only time your Python thread will run is after 100 Python virtual instructions have been executed in the main thread (see sys.setcheckinterval in the Python docs for more info).
If your thread is only performing computations or file i/o, then I would recommend setting this flag. If your thread is modifying the Vizard scene graph, then I would NOT set this flag.
Vizard won't run wouters Vizard 5 02-05-2008 12:12 PM
McAfee Privacy Service 8.1 causes Vizard not to run mspusch Vizard 0 03-01-2007 09:24 PM
Matlab and Vizard brystewa Vizard 1 09-18-2006 04:11 PM
wxPython with Vizard farshizzo Vizard 18 09-29-2005 09:49 AM
