Old 05-05-2008, 06:17 AM
joeymax joeymax is offline
teleport users location
Hi there,
Is there a way to teleport your location to a different part of your scene at the touch of a button:
For example…
theview = viz.get(viz.MAIN_VIEWPOINT)
theview.translate(0,5,0)
POSITION = 0
def mytimer(num):
	global POSITION
	if POSITION == 1:
		theview.translate(1,0,1)
	if viz.iskeydown('e'):
		POSITION = 1
..now I know this code doesn’t really work, but hopefully you can see what ive tried to do.
Any help would be much appreciated
Old 05-05-2008, 01:22 PM
What you have should work. If you have collision enabled, then you will need to temporarily disable collisions when teleporting the viewpoint.
viz.collision(0)
viz.MainView.translate(1,0,1)
viz.collision(1)
If you have linked a sensor to the viewpoint, then you will need to apply an offset to the link, instead of translating the viewpoint.
Old 05-05-2008, 04:49 PM
thankyou!! it works perfect now
Gps input for viewpoint location? realvision Vizard 3 03-19-2008 01:37 PM
For users with a floating license: Adding Vizard License Server as a Service mspusch Vizard 0 03-03-2006 12:36 PM
dynamic access of avatar location valhalla Vizard 1 09-13-2004 09:28 PM
