Old 04-24-2008, 09:51 AM
nige777 nige777 is offline
RE: Right answer, wrong question!
Thanks for the suggestion, it works really well. Unfortunately I posted the question when I was half asleep, so I apologies for the fact that I will now have to ask you a revised question. I actually need to be able to dismount the the truck and move around. I control the truck with a joypad with the head ori of the view set to mouselook and envisage controlling the view in the same way when I dismount. Here's the joypad script I'm using to drive the FLT:
#Use joystick to control FLT navigation
def UpdateMovement():
    #Get the joystick position
    x,y,z = joy.getPosition()
    #Get the twist of the joystick
    twist = joy.getTwist()
    #Using the z value off the twist control for up and down
    if abs(y) > 0.3 or abs(y) < -0.3:
        SetThrottle(-y)
    if abs(y) <0.3 and abs(y) >-0.3:
        SetThrottle(0)
    if abs(twist) > 0.2 or abs(twist) < -0.2:
        steer(twist*70)
        steerWheel(-twist*65)
    elif abs(twist) < 0.2 or abs(twist) > -0.2:
        steer(0)
        steerWheel(0)
#UpdateJoystick every frame
vizact.ontimer(viz.FASTEST_EXPIRATION,UpdateMovement)
So what I think I am asking is how do I mount and dismount from the truck while using the same controls to manipulate the main view.
Thanks for your patience,
Nige
General question and question regarding arrays dan12345 Vizard 1 01-15-2008 11:15 AM
Stereo Overlap question JMOwens Vizard 2 01-08-2008 09:54 AM
viztask question asimbh Vizard 1 11-20-2007 10:12 AM
Another color question mjabon Vizard 4 07-31-2007 04:04 PM
Basic Joystick Navigation Question Plasma Vizard 2 01-29-2004 08:08 PM
