Old 02-15-2008, 06:07 PM
nige777 nige777 is offline
Me again!
Hi farshizzo,
Unfortunately the model is invisible, when i comment out the shader code the normal is mapped correctly now tho . I have taken the liberty of attaching the code and osg in the hope that you may be able to throw some light on this problem for me.
Kind regards
Old 02-19-2008, 02:42 PM
I modified the sample script from my previous post to load your osg file instead, and it worked fine. Did you use the *exact* same script with only the filenames changed?
Old 02-20-2008, 03:01 AM
Normal Mapping
Hiya Farshizzo,
Yes, all I altered was:
#ball = viz.add('basketball.osg')
ball = viz.add('Truck01.osg')
#normal_tex = viz.add('bball_normal.jpg')
normal_tex = viz.add('mybodynormalsmap.jpg')
Apart from altering the distance on the pivot camera and making the background blue that was all i did, but to no avail.
Is that what you meant?
Thank you for your patience with this matter,
Kindest regards,
Nige
Old 02-20-2008, 10:04 AM
I've attached a modified version of the script I posted that replaces the models/textures with yours. I've also made a small tweak to the fragment shader. Try these out, it should work.
Old 02-21-2008, 03:55 AM
Thank You!
. Perfect, thank you
environment maps, scenes, and you! vadrian Vizard 1 01-12-2005 04:04 PM
generating images for panoramas using cube maps bailenson Vizard 5 09-08-2004 08:32 PM
